Hi Phil, I am using Bentley V8 Map XM. In Map XM we have GUI called Map Manager (File --> Map Manager). With help of this one we can create Map Model. Once you have done this you can able to create buffer with help of Create Buffer dialog box. I want to do the same functionality with programing. I want create buffer for liner, point and polygon features. Is there any classes available to do this.
Ganesh
Again, why is it that you want to recreate something that already exists?
I want to create buffer around the feature after that I want to some analysis. If it is possible through Key-in command or VBA mean I can do some continues analysis within a click event. For Example create feature around the road network, and select the feature which are not snapped with main road. So that I can snap with main road. I need to snap line with point, Polygon with line. I want call this function programatically after taht in need to etch some feature.
For the next release, in the Q2 timeframe, we will have the ability to create a Bentley Map feature from a buffer. I hope this helps.
Keith Raymond
