Hi All,
I'm developing a MDL programm in Microstation V8 XM. I have a Cell (not shared cell) element in the desing file. The cell contains text and shape as sub elements. Just I want to read the file position of each sub elements and write it into a log also I want delete all the shape elements.
So how to read the file position of each sub elements inside the cell and how to delete it (for delete also i need file position)?
Please help me.
Thanks & Regards,
Jeyan
Loop over all elements in chain, if element is shape and you want remove it, use mdlElmdscr_removeElement.
To get elements file position, you can use elementRef_getFilePos or mdlElmdscr_getFilePos , but I do not think that it is good idea to delete component element this way...
EXAMPLE:
Dan
Hi Dan,
Thank you for your helpful solution.
