Hello guys,
I added a cell in my dgn and would now like to delete all cells that have the same name. Example: cell name: test, when running my mdl, all cells with the test nameshould be erased. Could someone help me? Thank you.
What have you done so far ? It's not easy to help without knowing what the problem is. Have you looked at the delivered examples ? Are you able to compile an mdl ? Any experience with programming ?
As for the 'problem': run through the file (via scanner) with a type test for cells and than delete all those elements that matches your need. There a re a number of examples for the scanner API, make sure you looked at them.
Couldn't you simply use "Select by Attributes" ?
Dear friends,
I researched on some sites and solved this problem. Thanks for the help.
