I am looking for an vba to place info in the title bar. It would be nice if there was a variable that you could set that it would read the _USTN_PROJECTDESCR variable and place the info in the title bar. I have several projects that are similar and some people are getting confused with what project they are working in. So I would like to be able to place the project description in the title bar. Is there anyway to do this?
It can be done with VBA with "Application.Caption"
[V8i SS4 08.11.09.829, BRCM, Promis-e, OpenPlant Modeler, OpenPlant PID, STAAD, RAM, ProSteel, InRoads, FlowMaster, Map, PondPack, StormCAD, Descartes]
Wow.. Now every Cad Manager can customise the Window Title to their company name.. cool.
Damn. wish I knew how to code vba.
Damon : Now every Cad Manager can customise the Window Title to their company name. Wish I knew how to code VBA.
Dont forget about config
MS_FULLPATHINTITLEBAR = 1
If you dant wanna use the free vba..lool.
Does anyone know the current code shown in the Title Bar Caption?
Determine if drawings is 2D or 3D?
Determine the drawing file's Version (V8 DGN, V7 DGN, 2000 DWG, 2004 DWG, ...)?
Determine if the drawing is Read Only?
Active Model Name?
Jason: Does anyone know the current code shown in the Title Bar Caption?
If you follow the link I posted earlier, it will lead you to some VBA code. You can modify that code to display whatever you want in the Title Bar.
Jason,
I would not look to grab that type of info from the title bar as it is just a string and can be changed by any program. It would be much better to use the Application and Document objects to determine the state of the drawing file.
