I have written a macro using Visual Basic that draws consecutive lines and arcs based upon entries from the user (boundary description). Immediately after a line has been drawn, how do I retrieve the end point coordinates of that line (xyz) and save it as a variable to be used later in the macro?
The user enters a bearing and distance for each segment and the macro is set up to keyin the bearing and distance (i.e. "di=1000,N 45^12"10' E") using the "Place Line Constrained" command. Is there a quick way to retrieve the end coordinates of each line as they are drafted in Microstation?
Thank you mwrbentley!
I was able to extract all of the information from the previous element using your recommendation. However, I'm struggling to extract the endpoint from this information. Two questions for you:
1) How do I cast the oElement as a line?
2) To get the last point do I just do the following: Lastpoint = LineElement.EndPoint
Here is a sample of what I have:
Dim startPoint As Point3d Dim point As Point3d, point2 As Point3d
Dim LastElement as Element
Dim BD_Entry As Variant
Dim LastPoint as Variant
CadInputQueue.SendKeyin "place line constrained"
point.X = startPoint.X point.Y = startPoint.Y point.Z = startPoint.Z CadInputQueue.SendDataPoint point, 1
BD_Entry = "DI=3000,n 45^12'12" & Chr$(34) & "W" CadInputQueue.SendKeyin BD_Entry
Set LastElement = ActiveModelReference.GraphicalElementCache.GetLastValidElement Lastpoint = LineElement.EndPoint
KeyInEntry = "Choose last" CadInputQueue.SendKeyin KeyInEntry Lastpoint = Object.AsLineElement.EndPoint
Thanks again!
jdawg: How do I cast the oElement as a line? To get the last point do I just do the following: Lastpoint = LineElement.EndPoint
Thank you Jon!
When I type "Set oLine = oElement As LineElement" I get an error reading, "Compile Error: Expected end of statement" and it highlights "As". Am I missing something obvious?
I haven't been able to check part 2 because I'm still struggling with Part 1.
This is what I have thus far:
Dim oElement As Element Dim oLine As LineElement
Set oElement = ActiveModelReference.GraphicalElementCache.GetLastValidElement Set oLine = oElement As LineElement
End Sub
Any thoughts?
jdawg: When I type Set oLine = oElement As LineElement I get an error reading, "Compile Error: Expected end of statement" and it highlights "As". Am I missing something obvious?
My typo: there is no space after As: use oElement.AsLineElement
Element is an abstract concept — all elements are instances of class Element. You can cast an Element to any concrete class, such as a LineElement, by using the AsXxxElement property.
Works like a charm!!!
Thanks again for your help!
