I have a Vba project which scans a dgn file and attaches 5 tags to each element. It runs much slower in Ustn XM then Ustn 2004. Why should this be? See attached text file to view time comparisons. TIA, Spike
TIA, Spike
So, you would like somebody to analyse your code? What kind of response would you expect from the garage if you telephoned and said, "My car doesn't go very fast. Please tell me how to make it go faster"?
This program has been working fine, first as a BASIC macro from 2000, then as a VBA since 2005.
Before I start posting code and sample DGNs etc., is it possible that the switch from OpenGL to DirectX
graphics in XM be a factor?
The various possibilities are quite numerous, so to narrow those down to the most probable causes, we would need to see your code.
Why should a change in the graphic sub-system affect your VBA code? Without code analysis, that's speculation. As Phil requests, you really have to show us your code in order for anyone to do anything but share your speculation.
