Need help with intercharacter spacing issues in text nodes
I am working on a script which will replace existing cells on a drawing with an updated version from our cell library. This is being done because of a driver from our customer to have certain cell symbology match those utilized in other documentation. I need to automate this because we are updating close to 3000 drawings, each of which has an average of 50-100 cells which will be affected.
The simple answer is to "replace" the cell. Unfortunately that can't work by itself because we have many cells which have pre-designated text areas, such as component names/identifiers and pin numbers, defined for use by the worker. A simple "Replace" of the cell will get rid of the text that was added to the cells.
To make matters worse, sometimes the text will not fit on a single line in the designated area, so it becomes a text node. This is where I am having difficulty.
Currently I have the code listed below working to do everything I need. Sorry if it is a bit long, and probably more convoluted than it needs to be. I generally start by writing code "off the cuff" to make it work, then refine and optimize it later.
My code is copying the text and/or nodes properly, and replacing the information into the cells once the cell has been replaced. It has been very difficult and frustrating, but I currently have all of the text and nodes in the correct format (font, sizes, justification, color, etc) with one notable exception.
Every text node has an error in the intercharacter spacing when it is replaced. The initial value for the intercharacter spacing in a cell is generally set to the same value as the text width. However, after the cell is replaced, when the node is copied back into it, the intercharacter spacing is set to 0.0002 instead of the pre-existing value. This is casuing all the characters on a line to be overlapped/stacked on top of each other.
What I need is help in determining how to read the current intercharacter spacing and then assign that value to the replaced text node. I don't know why the value isn't being copied with the rest of the text style settings. I also do not know why it is set to 0.0002 on every item I test, regardless of the original text or node's spacing. My edit text attributes tool is almost always set to 0.2, if that helps in any way.
I recently considered simply editing the text attributes after the fact, but am only able to find references for turning the intercharacter spacing checkbox on/off and nothing regarding how to set the value in VBA. I assume it would be via a "tcb->" value or something similar, but have not been able to find a good reference for one.
Any help would be greatly appreciated.
Option Explicit
    ' Stores the name of the border and design file
    Dim borderName As String, dgnName As String
    ' Stores the revision letter of the diagram file
    Dim revLetter As String
    ' Stores the border size number (5-12)
    Dim borderSize As Integer
    ' Standard number variables for manipulation
    Dim strLength As Integer, X As Integer
    ' Standard coordinate use
    Dim startPoint As Point3d, endPoint As Point3d
    ' Reference coordinates for placing items like cells and text
    Dim dropPoint As Point3d
    ' Array used to store all corner coordinates of the current fence for future reference
    Dim fencePoints() As Point3d
    ' Procedure to handle Modal windows, used simply to close them automatically when actions complete
    Dim modalHandle As New ModalHandler
    ' Pointer to a profile for searches/manipulation
    Dim scanCriteria As New ElementScanCriteria
    ' Pointer to an element value
    Dim enumerator As ElementEnumerator
    ' Pointers to current element or for making a duplicate element for manipulation
    Dim ele As Element, cellCopy As Element
    ' Pointer to an element contained within the current cell
    Dim cellEle As CellElement
    ' Value used for tracking what heirarchal level of a cell we are in
    Dim nestLevel As Long
    ' True or False value for determining if a text/node has not data
    Dim isBlank As Boolean
    ' For general troubleshooting and message boxes
    Dim Response As String
    ' For text format manipulation
    Dim textElem As TextElement
Sub UpdateCells(cellName As String, cellLibrary As String, fenceStartPoint As Point3d, fenceEndPoint As Point3d, cellStartPoint As Point3d)
' This is used to update existing cells in the drawing with newer versions.
' If the cell includes text or text nodes, it will copy the text information
' before updating the cell, to maintain user specified data. After the cell
' has been replaced, the text will be copied back into the cell using the
' current cells text styles to ensure everything looks right.
' This is currently only used for specific cells which are in known/designated
' locations, such as the initials, signatures, dates, revision statements and
' function blocks. Other cells will be addressed later, using their current locations.
' No block of any cell can have more than 4 lines of text, by drawing design
' standards, and no cell has more than 15 text/node points.
Dim cellExists As Boolean
Dim nodeCounter As Integer
Dim nodeArray(15, 4) As String
Dim firstElement As Long
Dim XLine As Long
cellExists = False
nodeCounter = 0
For X = 1 To 15
    nodeArray(X, 1) = vbNullString
    nodeArray(X, 2) = vbNullString
    nodeArray(X, 3) = vbNullString
    nodeArray(X, 4) = vbNullString
Next X
' Attach cell library and set active cell
    CadInputQueue.SendCommand "RC=C:\Documents and Settings\All Users\Application Data\Bentley\WorkSpace\System\OFD2\CELL\" + cellLibrary + ".cel"
    CadInputQueue.SendCommand "AC=" + cellName
' Select by cell name
    scanCriteria.IncludeOnlyCell cellName
    scanCriteria.ExcludeAllTypes
    scanCriteria.IncludeType msdElementTypeSharedCell
    scanCriteria.IncludeType msdElementTypeCellHeader
    ' Setup Scan Memory
    Set enumerator = ActiveModelReference.Scan(scanCriteria)
    ShowStatus "Updating elements"
    ' Step through the scan results
    Do While enumerator.MoveNext
        With enumerator.Current
            ' Copy all text items in the cell.
            ' This is needed for the Functions cell, which should have function names
            ' filled in if this is a revision to the drawing.
            ' Start by walking through the cell components
            nestLevel = 0
            Set cellEle = enumerator.Current
            Do While cellEle.MoveToNextElement(True, nestLevel)
                If Not cellExists Then
                    ' Now that we found it make sure we know it
                    cellExists = True
                End If
                ' Make a working copy of the element to manipulate data
                Set cellCopy = cellEle.CopyCurrentElement
                ' Check to see if it is a text node (all text items in the cell should be)
                If cellCopy.IsTextNodeElement Then
                    ' Update the node count
                    nodeCounter = nodeCounter + 1
                    ' Set up to copy all the lines to an array
                    For XLine = 1 To cellCopy.AsTextNodeElement.TextLinesCount
                        ' Copy the line to our array
                        nodeArray(nodeCounter, XLine) = cellCopy.AsTextNodeElement.TextLine(XLine)
                    Next XLine
                End If
            Loop
        End With
    Loop
            ' OK, cell text nodes are stored in an arry so now we can replace the cell.
            ' This code will delete the cell area and put a new cell in place, regardless
            ' of whether one exists or not, and regardless of the cell being dropped.
            ' Set Fence placement selection to Block and select the tool
            SetCExpressionValue "tcb->msToolSettings.fence.placeMode", 0, ""
            CadInputQueue.SendCommand "PLACE FENCE ICON"
            ' Send a data points to the fence tool
            CadInputQueue.SendDataPoint fenceStartPoint, 1
            CadInputQueue.SendDataPoint fenceEndPoint, 1
            ' Set Delete Fence Contents selection to Inside and select the tool
            CadInputQueue.SendCommand "FENCE DELETE"
            CadInputQueue.SendCommand "LOCK FENCE INSIDE"
            ' Send data point to the Delete Fence Contents tool.
            ' This deletes anything from that particular area, since
            ' the only thing that should be in there is the cell we want
            ' Place active cell
            CadInputQueue.SendCommand "PLACE CELL ICON"
            CadInputQueue.SendDataPoint cellStartPoint, 1
            ' Clear selections and return to default controls
            DrawingSetup.SetupControls
            ActiveModelReference.UnselectAllElements
            nodeCounter = 0
            scanCriteria.Reset
    ' Setup Scan Memory
            ' And now, we paste information back into the cell, from the array, if needed
                    Dim nodeTemplate As TextElement
                    Dim haveTemplate As Boolean
                    haveTemplate = False
                    Dim textEnum As ElementEnumerator
                    Set textEnum = cellCopy.AsTextNodeElement.GetSubElements
                    Do While (textEnum.MoveNext)
                        With textEnum.Current
                            If textEnum.Current.IsTextElement And Not haveTemplate Then
                                Set nodeTemplate = textEnum.Current
                                haveTemplate = True
                            End If
                        End With
                    Loop
                    Dim tempNode As TextNodeElement
                    Set tempNode = CreateTextNodeElement2(cellCopy.AsTextNodeElement, cellCopy.AsTextNodeElement.Origin, Matrix3dIdentity)
                    cellEle.Redraw msdDrawingModeErase
                    ' Max number of lines in the area should be 4, so we will limit the checks to that
                    For XLine = 1 To 4
                        If nodeArray(nodeCounter, XLine) <> vbNullString Then
                                tempNode.AddTextLine nodeArray(nodeCounter, XLine)
                        End If
                    Next XLine
                    Set textEnum = tempNode.GetSubElements
                        Dim textComp As Element
                        Dim nodeICS As Double
                        Set textComp = textEnum.Current
                        Set textComp.AsTextElement.TextStyle = nodeTemplate.TextStyle
                        textComp.Redraw
                    Loop
                    tempNode.Redraw
                    cellEle.AsCellElement.ReplaceCurrentElement tempNode
                    cellEle.Redraw
                    cellEle.Rewrite
                    ' And now we just need to fix the stupid inter character spacing bug issue
                    CadInputQueue.SendCommand "MODIFY TEXT"
' *** This is my latest attempt to fix the problem...
                    '   Set a variable associated with a dialog box
                    SetCExpressionValue "tcb->msToolSettings.changeText.textstyle", 0, "MODIFY"
                    SetCExpressionValue "tcb->msToolSettings.changeText.font", 0, "MODIFY"
                    SetCExpressionValue "tcb->msToolSettings.changeText.height", 0, "MODIFY"
                    SetCExpressionValue "tcb->msToolSettings.changeText.width", 0, "MODIFY"
                    SetCExpressionValue "tcb->msToolSettings.changeText.linespace", 0, "MODIFY"
                    SetCExpressionValue "tcb->msToolSettings.changeText.linespacetype", 0, "MODIFY"
                    SetCExpressionValue "tcb->msToolSettings.changeText.interchar", 1, "MODIFY"
                    SetCExpressionValue "tcb->msToolSettings.changeText.slant", 0, "MODIFY"
                    SetCExpressionValue "tcb->msToolSettings.changeText.linelength", 0, "MODIFY"
                    SetCExpressionValue "tcb->msToolSettings.changeText.underline", 0, "MODIFY"
                    SetCExpressionValue "tcb->msToolSettings.changeText.vertical", 0, "MODIFY"
                    SetCExpressionValue "tcb->msToolSettings.changeText.viewind", 0, "MODIFY"
                    SetCExpressionValue "tcb->msToolSettings.changeText.just", 0, "MODIFY"
                    SetCExpressionValue "gUseChangeAnnotationScale", 0, "MODIFY"
' *** ...but I can't find a code to use for setting the intercharacter spacing value.
                    '   Send a reset to the current command
                    CadInputQueue.SendReset
                    CommandState.StartDefaultCommand
                End If
            Loop
        End With
    Loop
        ' Place active cell
    End If
End Sub
**** Originally posted in the wrong forum ****
