I have a VBA function that runs when a design file is opened and closed. However, I need to add a IF... Then... Else statement that checks to see if there is a reference file attached when the design file is opened. If the reference file is attached, then turn the reference file display off. Else attach the reference file and turn the display off.
I have a VBA function that attaches the reference file that works perfectly. And the VBA function that runs when a design file is open or closed works great. I just need to get them to work perfectly together.
I cannot seem to get this IF.. THEN... ELSE statement right. Can anyone help?
We could help more if you were to post the two bits of code that you want to merge.
OK. Here is what I have:
Option Explicit
Private WithEvents m_OpenCloseHooks As MicroStationDGN.Application
Private Sub Class_Initialize()
Set m_OpenCloseHooks = MicroStationDGN.Application
End Sub
Private Sub Class_Terminate()
Set m_OpenCloseHooks = Nothing
Private Sub m_OpenCloseHooks_OnDesignFileOpened(ByVal DesignFileName As String)
CadInputQueue.SendCommand "vba run [AttRef_v8]AttRef;REFERENCE DISPLAY YellowPlot OFF"
Private Sub m_OpenCloseHooks_OnDesignFileClosed(ByVal DesignFileName As String)
CadInputQueue.SendCommand "REFERENCE DISPLAY YellowPlot ON"
CadInputQueue.SendCommand "save design"
AttRef_v8 is a routine that our customer gave us to use but it is password protected and I don't have access to the code. AttRef_v8 attaches a reference file called YellowPlot to the design file. I want to insert an IF THEN ELSE statement before AttRef_v8 routine in called. because some design files already have the YellowPlot reference attached and running the AttRef_v8 function attaches another YellowPlot reference. So everytime that design file is opened another reference is attached, which can get out of hand quickly.
I want the above routine to check if YellowPlot is attached. If it is, just turn off the display of the YellowPlot reference. If it is not attached, then run AttRef_v8 and turn off the display. Can you Help?
Try something like this (untested) code …
' --------------------------------------------------------------------- Public Sub AttachReferenceIfNotAlreadyAttached (ByVal name As String) As Boolean Dim oAttachment As Attachment Set oAttachment = IsAttached (name) If (oAttachment Is Nothing) Then ' Attach named file and turn display off CadInputQueue.SendCommand "vba run [AttRef_v8]AttRef;REFERENCE DISPLAY " & name & " OFF" Else ' Turn display off oAttachment.DisplayFlag = False End Sub ' --------------------------------------------------------------------- Public Function IsAttached (ByVal name As String) As Attachment Set IsAttached = Nothing Dim oAttachment As Attachment For Each oAttachment in ActiveModelReference.Attachments If (0 = StrComp (oAttachment.AttachName, name)) Then Set IsAttached = oAttachment Exit Function EndIf Next oAttachment End Function
