repost from v8 forum excel.application.ontimer "cannot run macro"
>I am using the "Application.ontimer" member of the excel library  to call a Public Sub GetTime()
>I am getting the error "Cannot run the Macro "GetTime" May not be available in this  workbook or all...."
>I've changed my security setting to "none" in Microstation XM, is there a place where I should look to see if macros are disabled?  I am running other vba, with no >problem.
The security setting that I changed is in the Microstation environment, under Workspace-Security
I add a clock to a vba form in Excel using the application.ontimer like:
    Dim ID As Date
    UFClock.clock =Format(Now, "mm/dd/yy hh:mm:ss")
    ID = Now +TimeValue("00:00:0001")
    UFClock.LastTime= ID
    Application.OnTime ID, "GetTime"
End Sub
I wanted to do the same in microstation, but there isn't the Application.ontimer  so I loaded the excel library and used excel.application.ontimer but it won't launch the "gettime"  I've also tried "ufclock.gettime" .
I have the gettime in a module, but I've also tried it in the form programming as a private function.
any help is greatly appreciated.
