How to get a particular microstation instance from running processes?
I am using c sharp.net. If I initiate the application object as below,
Application app = new ApplicationClass();
it either creates a new instance of microstation application or hooks to a currently running microstation instance.
When I have multiple microstation instances running, and I need to catch a particular instance, the above method do not work.
Any idea?
