VBA to drop specific cell
I'm using a macro to insert a specific cell with CadInputQueue.SendKeyin "active cell cellname"
How can I drop this cell into it´s components immidiately after it is placed? Should I use CadInputQueue.SendCommand "DROP ELEMENT" in some way?
  • It ends up with a Cache contains no valid elements error.
     The code now looks like this:
    Sub SkruvM24()
    Dim oLastElem As Element
    CadInputQueue.SendKeyin "attach library R:\Bentley\Workspace\Standards\Cell\Mskruv.cel"
    CadInputQueue.SendKeyin "active cell M24"
    Set oLastElem = ActiveModelReference.GraphicalElementCache.GetLastValidElement
    CadInputQueue.SendCommand "drop element"
    CadInputQueue.SendKeyin "XY=0;selview all"
    RedrawAllViews
    End Sub
    The Set oLastElem = ActiveModelReference.GraphicalElementCache.GetLastValidElement line gets hilighted when I debug.
  • Hi again
     Try this code instead:
    Sub SkruvM24()
    Dim oCellLib As String
    Dim oCellName As String
    Dim oMessage As CadInputMessage
    Dim pPoint As Point3d
    ' Cell library to attach
    oCellLib = "R:\Bentley\Workspace\Standards\Cell\Mskruv.cel"
    'Cell name
    oCellName = "M24"
    'Attach a cell library
    AttachCellLibrary oCellLib
    ' Set a cell avtive
    ActiveSettings.CellName = oCellName
    ShowPrompt ("Place Cell")
    CadInputQueue.SendCommand "PLACE CELL"
    Set oMessage = CadInputQueue.GetInput(msdCadInputTypeDataPoint, msdCadInputTypeReset)
    If oMessage.InputType = msdCadInputTypeDataPoint Then
    pPoint = oMessage.point
    ElseIf oMessage.InputType = msdCadInputTypeReset Then
    CommandState.StartDefaultCommand
    End
    End If
    CadInputQueue.SendDataPoint pPoint, 1
    CadInputQueue.SendReset
    CadInputQueue.SendCommand "UPDATE VIEW EXTENDED 1"
    ActiveModelReference.UnselectAllElements
    RedrawAllViews
    End Sub
Reply
  • Hi again
    Sub SkruvM24()
    'Cell name
    oCellName = "M24"
    ' Set a cell avtive
    End
    End If
    RedrawAllViews
    End Sub
