I can't find the msfontmgr.fdf file anymore. Is it deprecated?
I need the function mdlFontMgr_traverseAvailableFonts. Is there any other funtion that can be used instead?
Thank you Jon and Jeff.
The application is completely writen in MDL. It will take to much time to migrate the application to new MicroStation API.
Alexander: The application is completely writen in MDL.
Bentley have given a few hints over the past year or so about C++. Developers should consider moving applications to a DLL written using C++ (i.e. Visual Studio).
We can continue to call functions in the MicroStation Development Library directly, as we do in a pure MDL application. However, some functionality has moved to the MicroStation API, which contains C++ interfaces that are not available in pure MDL. You may not want to re-write your current application in C++, but the problems you have seen are indicative of what is to come.
