how to use mdlMeasure_closestPointOnElement()
hello all,
I want to use the function mdlMeasure_closestPointOnElement() to get the closest Point of a linestring element to my cursor Point.
But I don't know how to get the pHandle, which I need for this function.
StatusInt mdlMeasure_closestPointOnElement
DPoint3d* pClosePoint ,            OUT
ElemHandleCP pHandle ,          IN
DisplayPathP pPath ,                   IN
DPoint3d const* pSpacePoint    IN
Any suggestions or code example ?
best regards,
Martin
  • Obfuscation by Macro
    Martin:
    I want to use the function mdlXxx. But I don't know how to get the ElemHandleCP pHandle, which I need for this function.
    In the excitement of moving towards C++ in V8i, documentation and cross-referencing have suffered. ElemHandle is part of the MicroStationAPI C++ interface. You will find <ElemHandle.h> in \MicroStationAPI\interface.
    <mstypes.h> (in \mdl\include) uses a macro ELEMENT_TYPEDEFS to derive various typedefs from a root typedef. That macro is used to generate various typedefs from ElemHandle, so when you search for a definition of ElemHandleCP you won't find one.
    If you look at the MicroStationAPI help file, you will find a section on Element Handler. For example:
    ElemHandle  ( ElementRef  elRef,
    DgnModelRefP  modelRef
    Regards, Jon Summers
    LA Solutions
    LA Solutions
Reply
    Martin:
    LA Solutions
    LA Solutions
