I am trying to get a listbox cell to be editable, but cannot get it to work. What am I missing? Below is the create from the listbox create hook and the Ditem_listboxrsc definition:
case DITEM_MESSAGE_CREATE: {
int i,numCols=2;
ListModel *pListModel,*usedPListModel;
ListCell *pCell = NULL;
ListRow *pRow = NULL,*newPRow=NULL;
if (NULL == (pListModel = mdlListModel_create (numCols)))
dimP->u.create.createFailed = TRUE;
break;
usedPListModel = mdlListModel_create (numCols);
if (SUCCESS != mdlLevelList_getLevelNamesListModelEx (pListModel, MASTERFILE, LEVEL_DEFAULT_LEVEL_ID, LEVELLIST_BOLD_USED))
{ mdlListModel_destroy (pListModel, TRUE);
break; }
// show only used levels
for(i=0; i<mdlListModel_getRowCount(pListModel); i++) {
pRow = mdlListModel_getRowAtIndex (pListModel, i);
pCell = mdlListRow_getCellAtIndex (pRow, 0);
if(FONT_INDEX_BOLD==mdlListCell_getFontIndex (pCell)) {
mdlListRow_create (usedPListModel);
newPRow=mdlListRow_copy (pRow);
mdlListModel_addRow(usedPListModel,newPRow); } } mdlDialog_listBoxSetListModelP(dimP->dialogItemP->rawItemP,usedPListModel,1); break; }
DItem_ListBoxRsc LISTBOXID_ExportDTMLevels = { NOHELP, LHELPCMD, HOOKITEMID_ExportDTMLevelSelection, NOARG, LISTATTR_DYNAMICSCROLL | LISTATTR_RANGESELECTION | LISTATTR_DISJOINTSELECTION | LISTATTR_NOSELECTION | LISTATTR_EDITABLE | LISTATTR_FONTBYCOLUMN, 8, 0, "Select Levels", { {18*XC,50, ALIGN_LEFT, ""}, {5*XC,3, LISTCOLATTR_EDITABLE | ALIGN_RIGHT, "FC"}, } };
Ray: I am trying to get a listbox cell to be editable, but cannot get it to work.
You are right to use a ListModel, but incorrect in assuming that a ListBox can be edited. The ListBox is merely the presentation device for a ListModel, and presentation devices can't edit.
Cells in a ListModel can be edited, and the mechanism to achieve that is to assign a cell editor to an individual cell, or more usually to an entire column or row. Take a look at our page that describes MDL ListModels, ListCells, and Cell Editors.
If you scroll to the end of that page you'll find the Datasheet example, which is a modified version of one that Mark Anderson gave out several years ago.
