Hello
I have some code where I call print organizer key-ins. I'm trying to set the print destination to my pdf file to c:\temp\.
I have already made a pset file where I set the default print definition name to <model name> and the output file name to <design name>. Here is the code:
private void toolStripButtonPrint_Click(object sender, EventArgs e)
PrintFrm form = new PrintFrm(toolStripComboBoxPages);
DialogResult dr;
string model;
int count = 0;
dr = form.ShowDialog();
if (dr == DialogResult.OK)
RunProgressBar rpb = new RunProgressBar();
rpb.progressbar.Minimum = 0;
rpb.progressbar.Step = 1;
if (mainAddin.Instance._language.ToLower().CompareTo("norsk") == 0)
rpb.Text = "Skriver...";
else
rpb.Text = "Printing...";
rpb.Show();
rpb.Refresh();
if (form.page == 0)
rpb.progressbar.Maximum = 9;
else if (form.page == 1)
rpb.progressbar.Maximum = form.pageTo - form.pageFrom + 9;
rpb.progressbar.Maximum = toolStripComboBoxPages.Items.Count + 8;
rpb.progressbar.PerformStep();
// Initialize print organizer
BIM.Session.Instance.Keyin("mdl load bentley.microstation.printorganizer.dll");
// Finds pset file
string organizerFileName = mainAddin.Instance.ActiveSettings.Printers[form.printerDriver].OrganizerFile;
string printerDriverFileName = mainAddin.Instance.ActiveSettings.Printers[form.printerDriver].PrinterDriver;
string fullFileName = ISYSettingsMicroStationMethods.FindFileUsingConfigVarValue("TCPLOT_PLOTCFG", organizerFileName);
// Adds pset file
if (fullFileName == null)
BIM.Session.Instance.Keyin("PRINTORGANIZER NEW");
BIM.Session.Instance.Keyin("PRINTORGANIZER OPEN " + fullFileName);
// Adds printer driver
BIM.Session.Instance.Keyin("PRINTORGANIZER PRINTERDRIVER " + printerDriverFileName);
if (isSystemPrinter(printerDriverFileName))
// Adds printer
BIM.Session.Instance.Keyin("PRINTORGANIZER PRINTERNAME " + form.printer);
// Adds # of copies
BIM.Session.Instance.Keyin("PRINTORGANIZER PRINTCOPIES " + form.copies);
// Adds print destination
string desname;
desname = "C:\\temp\\";
BIM.Session.Instance.Keyin("PRINTORGANIZER PRINTDESTINATION " + desname);
// Adds models
model = "PRINTORGANIZER ADD MODEL \"" + _attachedLibrary + "\" \"" + toolStripComboBoxPages.Text + "\"";
BIM.Session.Instance.Keyin(model);
foreach (object item in toolStripComboBoxPages.Items)
if (count >= form.pageFrom && count <= form.pageTo)
model = "PRINTORGANIZER ADD MODEL \"" + _attachedLibrary + "\" \"" + item.ToString() + "\"";
count++;
//Adds paper size
BIM.Session.Instance.Keyin("PRINTORGANIZER APPLYPRINTSTYLE ALL " + form.paperSize);
// Other
BIM.Session.Instance.Keyin("PRINTORGANIZER SUBMITAS SINGLE");
BIM.Session.Instance.Keyin("PRINTORGANIZER PRINT ALL");
if (mainAddin.Instance._language.ToLower().CompareTo("norsk")==0)
rpb.Text = "Print ferdig.";
rpb.Text = "Print Complete.";
BIM.Session.Instance.Keyin("PRINTORGANIZER EXIT");
rpb.Close();
form.Close();
:end code
Even though I set (PRINTORGANIZER DESTINATION C:\temp\) the pdf file still goes to
MS_DGNOUT. Can anyone tell me what I'm doing wrong?
regards,
Øyvind Olsen
Norconsult Informasjonssystemer AS
I keyin the following command sequence after I open my test.pset in Print Organizer
PrintOriganizer PrintDestination C:\Temp PrintOrganizer Print All
The output pdf files are really created into C:\Temp folder. Please make sure if the C:\Temp folder exists in your box.
I found out what was wrong. When the "SUBMITAS" keyin came after the
"PRINTDESTINATION" keyin, the "SUBMITAS" keyin overwrote the print destination...
This Worked:
// Adds print destination string desname = mainAddin.ComApp.ActiveDesignFile.FullName; desname = desname.Replace(".dgn", ".pdf"); model = "PRINTORGANIZER PRINTDESTINATION \"" + desname + "\""; BIM.Session.Instance.Keyin(model);
Thank you for helping
I have one more question to this issue.
Is the "SUBMITAS" keyin nessary when the "PRINTDESTINATION" keyin is used...?
Seems to me that they overwrite eachother...
The SUBMITAS option only plays a role for PDF output because here you can create a single composite PDF file or separate PDF files.
For this workflow, PRINTDESTINATION and SUBMITAS are related. If SUBMITAS is SINGLE then PRINTDESTINATION must be a file name. If SUBMITAS is SEPARATE then PRINTDESTINATION must be a folder name.
This is the problem I saw in the initial snippet of code you posted. You set SUBMITAS to SINGLE but then specified a folder name for PRINTDESTINATION. In the more recent snippet you posted, PRINTDESTINATION was correctly set to a file name.
As to the order of the keyins, currently you must specify SUBMITAS before PRINTDESTINATION. One could argue that the order should not matter, and I agree. I will file a Trouble Report (TR) for this so that it is fixed for the next release.
Thanks.
Dennis Abreo
Dennis,
Thank you for your reply. That clarified my problem...
