<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>setting root directory for shp import</title><link>https://communities.bentley.com/products/programming/microstation_programming/f/archived-microstation-v8i-programming-forum/60343/setting-root-directory-for-shp-import</link><description>Hi all, 
 I need to set a default directory as root directory for shp file import in MSV8i and MAP V8i. The steps are: from File menu -&amp;gt;Import-&amp;gt;Gis data types and then from Interoperability dialog Imports-&amp;gt;import1-&amp;gt;Add file and then the dialog shows</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>Re: setting root directory for shp import</title><link>https://communities.bentley.com/thread/145218?ContentTypeID=1</link><pubDate>Tue, 28 Sep 2010 18:24:37 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:c049c37f-5401-4a28-ba84-13a74503b3a2</guid><dc:creator>Jeff Bielefeld</dc:creator><description>&lt;p&gt;...the MS_GEOPROJHOME variable defines the default import directory.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
