I creates an addin which runs in XP.In XP I simply load the .Net dll only once.The next time I launched MicroStation the dll gets loadung automatically.
I created a form based on BMW and put some commands on it.If I call - ActiveDesignFile.Close() the addin gets unloaded- OpenDesignFile(...) the addin gets loaded again
Now I moved to Windows7 and the AddIn doesn't get autoloaded anymore.Are there anybody who has a hint to solve this issue?
code:
[Bentley.MicroStation.AddIn(MdlTaskID ="MyName"]internal sealed class Connector : Bentley.MicroStation.AddIn, _ApplicationEvents{ ...
How do you load your application?
Hi Jon,
I copied the dll to '...\Bentley\MicroStation\mdlapps' and load the dll via the menu,
Utilities -> MDL Applications
in the form I use the "Browse ..." button to load the dll.
It appears in the "Loaded Applications" list (the "Key-ins" button is disabled)
That is the same in XP and Windows7.
In XP it creates automatically a ".ma" file:
"C:\Dokumente und Einstellungen\user\Lokale Einstellungen\Temp\Bentley\MicroStation\8.11\XxVInaNgz5Rpcrf3CtvOww\AddInLoader1.0\PS.Pinpoint.PlugIn.MicrostatV8i.ma"
I can check the ".ma" file in the overridden int AddIn.Run(string[] commandLine) ... method.
The Run method is called in Windows7 too and I can see the ".ma" in the commandLine parameter.
In XP I find the ".ma" on the disc too, but in Windows7 the related directory is not populated with the ".ma" file.
Thomas
oh, I looked at the wrong location, in Windows7 the .ma file is saved in:
C:\Users\User\AppData\Local\Temp\Bentley\MicroStation\8.11\o_Dof88niaENmS1PChQ4Mg\AddInLoader1.0\MyAddIn.ma
But still the dll gets not loaded automatically :-(
The file that you found is created on the fly to load some legacy processing for applications. I would suggest looking at configuration differences or were there any other changes to the system besides Windows 7? Are the events getting fired off?
HTH,
mark anderson [Bentley]
Visit me at https://communities.bentley.com/communities/other_communities/bentley_innovation/default.aspx
twegener said:The next time I launched MicroStation the DLL gets loaded automatically
A pure MDL application is loaded in the following circumstances …
or
In all cases except 1, the application must be written to behave correctly when loaded as either an MS_DGNAPPS or an MS_INITAPPS.
Is a .NET AddIn expected to behave differently?
thanks for your hints, if I use these methods it works on Windows7. Curiously these methods are not applied on the XP machine and it, but it works ...
Thanks the issue is solved ...
