I know that TextParam.font can be used to set the text font number (UInt32). My question is, how do I determine the font number of a Windows TTF, specifically the Areial font?
Attached is some code that I have used to explore around the FontManager and Font classes. It shows how you can get the number from the name. Be sure to review the documentation on FontManager in the MicroStationAPI help file.
HTH,
mark anderson [Bentley]
Visit me at https://communities.bentley.com/communities/other_communities/bentley_innovation/default.aspx
Once again, thanks Mark!
