IDockChangeListener Interface
What commandstate and eventhandler that enables the IDockChangeListener inteface?
Dim cls As clsDockChangeListner cls = New clsDockChangeListner
where the class is...
Imports Bentley.WindowingPublic Class clsDockChangeListner
Implements Bentley.Windowing.Docking.IDockChangeListener
 End Class
for example.
The command...
ustn.CommandState.StartLocate cls
enables the
Implements ILocateCommandEvents
Sub StartLocate(EventHandlers As Bentley.Interop.MicroStationDGN.ILocateCommandEvents) Member of Bentley.Interop.MicroStationDGN.CommandState
and ustn.CommandState.StartPrimitive(cls) enables the
Implements IPrimitiveCommandEvents Sub StartPrimitive(EventHandlers As Bentley.Interop.MicroStationDGN.IPrimitiveCommandEvents, Optional WantKeyins As Boolean = Nothing) Member of Bentley.Interop.MicroStationDGN.CommandState
  • Here is a snip of some code that I used for the IDockChangeListener interface:
    using System;
    using System.IO;
    using System.Collections.Generic;
    using System.ComponentModel;
    using System.Data;
    using System.Drawing;
    using System.Linq;
    using System.Text;
    using SWF = System.Windows.Forms;
    #region "Bentley Namespaces"
    using BMW = Bentley.MicroStation.WinForms;
    using BMI = Bentley.MicroStation.InteropServices;
    using BCOM = Bentley.Interop.MicroStationDGN;
    using BM = Bentley.MicroStation;
    using BW = Bentley.Windowing;
    using BWD = Bentley.Windowing.Docking;
    #endregion
    namespace Initaddin
       public partial class InitForm : BMW.Adapter, BWD.IDockChangeListener //System.Windows.Forms.Form//
           private BW.WindowContent m_windowContent;
           private string m_baseDirectory;
           private string m_fileName;
           public InitForm(BM.AddIn addIn)
               //AttachAsGuiDockable(addIn, this.Text);
              // textBox1.Text = "c:\\ddrive\\data\\dgn\\";
               AttachAsTopLevelForm(addIn, true);
               this.Width = 300;
           /* Make the form dockable in MicroStation */
               this.NETDockable = true;
               BW.WindowManager windowManager = BW.WindowManager.GetForMicroStation();
               m_windowContent = windowManager.DockPanel(this, this.Name, this.Text, BW.DockLocation.Left);
               //m_windowContent.Undockable = true;
               //m_windowContent.CanAutoHide = true;
               //m_windowContent.CanDockHorizontally = false;
               InitializeComponent();
               populateFileList();
           public System.Windows.Forms.ListBox GetListBox()
               return listBox1;
           private int populateFileList()
               string[] listing;
               m_baseDirectory = "c:\\ddrive\\data\\dgn\\";
               listing = Directory.GetFiles(m_baseDirectory, "*.dgn");
               foreach (string file in listing)
                   listBox1.Items.Add(file);
               //listView1.View = SWF.View.List;
               //listView1.Dock = SWF.DockStyle.Fill;
               return listing.Count();
           private void SelectedItem(object sender, SWF.MouseEventArgs e)
               string fileName = listBox1.SelectedItems[0].ToString();
               BMI.Utilities.ComApp.OpenDesignFile(fileName, false, BCOM.MsdV7Action.UpgradeToV8);
              // this.Hide();
           /// <summary>See IDockChangeListener.</summary>
           /// <author>Wil.Maier</author>                                <date>08/2008</date>
           public void OnUndocked
           SWF.Control newParent
           public void OnDocked
           SWF.Control newParent,
           SWF.DockStyle where
           public void OnDocking
           SWF.DockStyle where
           public void OnUndocking
           public void OnParentClosing
           System.ComponentModel.CancelEventArgs args
           private void listBox1_MouseDoubleClick(object sender, SWF.MouseEventArgs e)
               SelectedItem(sender, e);
    HTH,
