Hi, I am trying to set docked extents for resizeable NetDockable dialog without luck...
In .NET this can be handled by MinimumSize property of attached control, but what to use in MDL/MFC?
I have used mdlNativeWindow_getNETDockedExtents and in SecondaryDialogHook have it set, but without luck...
This is what I do for wanted region:
RECT rect; GetClientRect(m_hWnd, &rect); dmP->u.dockedExtent.dockExtent.x = rect.right; dmP->u.dockedExtent.dockExtent.y = rect.bottom; dmP->u.dockedExtent.extentFlag = DOCKEXTENT_SPECIFIED;
This for unwanted:
dmP->u.dockedExtent.extentFlag = DOCKEXTENT_INVALIDREGION;
Unwanted regions are disabled, but docked extents are still about 100 units in width and my dialog has 200 units width at least.
Should it work?
Dan
