Hi all,
I have a DGN file which has an attached reference file(DGN). How to read this reference file along with the main file?
From the microstation help, I got that we need to activate the attached reference. How can we activate the reference without disturbing the current active model ? I did not find any API to activate a reference. Please somebody help me.
Thanks in advance.
Unknown said:I have a DGN file which has an attached reference file(DGN)
DGN files contain models. A model may have reference attachments, which are themselves a model in a DGN file. That is, DGN files do not have attachments.
Unknown said:I did not find any API to activate a reference
mdlSystem_exchangeToReference
The attachments are modelreferences. You would normally use the modelrefiterator and get the model reference you are interested in. Most of the API will take in a model ref as a parameter so you can work with the references as just another model. I don't think that you are looking to activate the model but there is api in the MicroStationAPI to do this as well.
HTH,
marka
mark anderson [Bentley]
Visit me at https://communities.bentley.com/communities/other_communities/bentley_innovation/default.aspx
Thank you all. Got it.
