Dear VBA experts,
I am trying to create a routine that will batch process files to manipulate the sequence order of attachments in a design model file. I am trying to move the ActiveDesignFile to the end of the order. This in general is achieved by clicking Settings > Update Sequence, in Reference Dialog box.
The following codes has some problems due to which the ActiveDesignFile doesn't move all the way to the bottom if the sequence order of attachments is not incremental. i.e. 1,2,3,4 and so on. For example if I update the sequence in the order of 1,4,3,2 this routine with move the ActiveDesignFile below the attachment order of 4.
The codes traces just fine except the final results don't come as expected. Your help would help me debug and understand the situation. Here is my code. The attached file is the mbva file of the same. You can simple rename it to remove the "zip" extension from this file.
Option Explicit
Sub UpdateSequence_ActiveModel_ToEnd() 'MicroStation related variables Dim attachmentsCount As Long attachmentsCount = ActiveModelReference.Attachments.Count Dim expectedSum As Long Dim currentSum As Long Dim missingNumber As Long 'Assign currentSum to Zero to begin with currentSum = 0 Dim i As Integer Dim tempArray() As Variant ReDim tempArray(attachmentsCount - 1) 'Check if the model has attachments if not exit sub If (ActiveModelReference.Attachments.Count <> 0) Then 'If the model has only one attachment then change the updateorder to 0 immediately and exit If (ActiveModelReference.Attachments.Count = 1) Then ActiveModelReference.Attachments(1).UpdateOrder = 0 'Save Settings so that the update order is saved. SaveSettings 'Redraw all views to reflect changes RedrawAllViews Exit Sub Else 'Find the expectedSum to compare against expectedSum = (attachmentsCount + 1) * (attachmentsCount / 2) 'Loop though each attachments item For i = 1 To attachmentsCount 'Populate a temporary array with the current update orders tempArray(i - 1) = ActiveModelReference.Attachments(i).UpdateOrder currentSum = tempArray(i - 1) + currentSum Next i 'Find the missing number missingNumber = expectedSum - currentSum 'MsgBox ("Missing Number is: " & missingNumber) 'Update the rest of the attachments to bring current model to the highest order If (missingNumber = attachmentsCount) Then 'The active design file is the last in the order. Thus exit. SaveSettings RedrawAllViews CadInputQueue.SendCommand "Dialog -127" Exit Sub Else For i = 1 To attachmentsCount If (tempArray(i - 1) > missingNumber) Then ActiveModelReference.Attachments(i).UpdateOrder = tempArray(i - 1) - 1 'MsgBox tempArray(i - 1) 'SaveSettings 'Update the views 'MsgBox ("Reference name is: " & ActiveModelReference.Attachments(i).AttachName & " & UpdateOrder is: " & ActiveModelReference.Attachments(i).UpdateOrder) End If SaveSettings Next i End If End If Else Exit Sub End If 'SaveSettings RedrawAllViews 'MsgBox ("Reference name is: " & ActiveModelReference.Attachments(i).AttachName & " & UpdateOrder is: " & ActiveModelReference.Attachments(i).UpdateOrder) CadInputQueue.SendCommand "Dialog -127" End Sub
Hi Rabi, Here's my routine for changing the reference file update order. The "Reset" button changes the active file to be the last file updated (on top of all the other references). Please note that there are three parts to the routine, the module, the user form, & the class module. Most of the code in in the user form. (right click & view code).
--Good luck, --Robert
Alright I have finally created a macro to move the active design file to the end of the sequence. Please use at your own risk. You need to load this mvba in MicroStation to use it. Please refer to the documentation provided by Bentley on how to open and run mvba's in MicroStation. This works for Bentley MicroStation XM edition.
This macro creates a log file in your C:\ . Please look for C:\updateSequence.log.
Enjoy!
Rabi
PS: Thank you Robert for your help.
Thanks, this has been quite helpfull.
