Hello. I want to get the annotation scale from an empty model. And I want to use it to set the right level active.
My skil to program in VBA is not very best, so if you want to help me, plaese do
Martin
From part of an example I have, to get the Annotation Scale:
Sub Scales()
Dim asf As Double
' lock must be on to continue
If ActiveSettings.AnnotationScaleEnabled = False Then
Exit Sub
' get annotation scale
asf = ActiveModelReference.GetSheetDefinition.AnnotationScaleFactor
End Sub
HTH...
Microstation SS3 08.11.09.714
ProStructures V8i SS8 v8.11.14.238
Thanks Steve.
You help me a lot. Afther all, the solution is quite simlpe but to find that....
