Is there a way to encode or similar our VBA code, or make it not accessible/viewable to users, so that others can't copy/modify our code?
Graham
Hi Graham,
yes, it is a standard feature of VBA environment. You can protect your VBA with password, in VBA editor go to Tools > Default properties > tab Protection.
HTH Jan
Excellent. Thanks Jan.
(I thought I was going to have to do something with Digital Signatures, which I didn't want to start doing)
You can't... VBA Password Bypasser and similar tools are usable to unlock ANY VBA protection...
If you want to make "really" protected tool, you have to compile it... But still, as all compiled, unfortunately, then it can be disassembled...
DanPaul,
I used to give password to my vba codes. Now, I understand that I have to compile my code to make "really" protected tool.
If you mean to use compile under Debug menu, then I compiled my password protected mvba code now. But I dont understand how much I protected it.
What is the difference between compiled mvba and only password protected mvba?
Olcay
oebcin: I used to give password to my vba codes.
The password protection built in to VBA by Microsoft is weak. It can be broken using publicly-available methods. Its purpose is to reduce idle curiosity by users: if a macro is modified, a user must have broken the password.
oebcin: If you mean to use compile under Debug menu, then I compiled my password protected mvba code now. But I dont understand how much I protected it.
VBA compile doesn't do a lot, and it certainly doesn't stop someone breaking your VBA password and examining your source code. If you really need secure code, then move non-MicroStation functionality into a ActiveX (COM) DLL built with another tool (i.e. VB6 or C++), and reference that from your VBA code.
Jon Summers: If you really need secure code, then move non-MicroStation functionality into a ActiveX (COM) DLL built with another tool (i.e. VB6 or C++), and reference that from your VBA code.
Why only non-MicroStation functionality? If you reference COM object inside of ActiveX DLL, then its internal MicroStation functionality will be usable only within MicroStation so it should be legal, or not?
oebcin:
I never really needed compiled MVBA code, but I made some DLLs (to test it only) by simple exporting modules from VBA and then inporting them into VB6. Problems becomes with Forms, because there is little bit different meaning about forms in VBA and forms in VB6, because forms from VBA needs MDI container, so it's better to compile only functionality, not UserForms...
There is also option to use .NET and compile as new COM...
DanPaul: Why only non-MicroStation functionality? If you reference COM object inside of ActiveX DLL, then its internal MicroStation functionality will be usable only within MicroStation.
You're absolutely right. The reason that I don't put MicroStation functionality in an ActiveX component is that I can use that same component from outside MicroStation. For example, I can build a database interface component as an ActiveX, then use that component from both MicroStation VBA and a VB application executable.
DanPaul: There is little bit different meaning about forms in VBA and forms in VB6, because forms from VBA needs MDI container, so it's better to compile only functionality ...
There's another reason not to put all your VBA stuff into a DLL!
This discussion is somewhat moot — anyone who doesn't have Visual Studio 6 (with VB6) is going to have a hard time acquiring it now. Microsoft wants us to use .NET, and does not want us to use VB6.
Jon Summers: You're absolutely right. The reason that I don't put MicroStation functionality in an ActiveX component is that I can use that same component from outside MicroStation. For example, I can build a database interface component as an ActiveX, then use that component from both MicroStation VBA and a VB application executable.
Aha, now I see how did you mean it :), but this is discussion about protecting a MVBA code, so we can suppose that it can be completely based on MicroStation functionality...
Jon Summers: Microsoft wants us to use .NET, and does not want us to use VB6.
Yes, they wants and it is not problem. It just needs a very little bit more of work to do it and still it is just close to copy-pasting of existing code, but now into VB.NET COM Class, but we should not forget about obfuscation :)
Thanks a lot.
you helped me a lot.
Now, I can protect my codes better than before :)
regards,
Jon Summers:Microsoft wants us to use .NET, and does not want us to use VB6.
Microsoft wants too many things in my view..., and this may be a good reason for exploring alternative software (Borland software for example)
DanPaul:but we should not forget about obfuscation :)
Yes, I agree with Dušan, but in the context of my comment above.
Marcos
