I am constantly doing layouts that involve using Arc, radius, chord & angle, where two of those are known, and the other two are unknown (needs to be either layout or manually calculated). I already have an excel spread sheet to doing something similar. I was just curious if there are any programs out there that do any kind of arc, chord & angle type of manipulation. For example, where it prompts you for a radius (the user would either input a radius on the number keypad or could measure/select two point in the drawing as input radius). then it would prompt you for either a chord or angle in the same manner. Then it would generate the solution as a text.
It's a lot quicker to input arc or angle, with a click of a mouse, then inputting into excel (and possibly making a typing mistake); and having to measure radius, or angle, then transcribing it to excel into the appropriate cell to solve the unknowns variable. Then having to copy the results, back to microstationas text. I am sure, I am not the only one that has ever needed such a program, and was just curious if there was one already written by someone (or something similar relating to solving for arc, chord, radius or angle). Thanks
thanks, and how long did it take you to write it from scratch?
ball888 said:How much work would it be to convert this macro to vba?
Some.
Attached is a ZIP archive that contains a DGN file and a VBA project file BearingAnnotator.mvba. The DGN shows a 'star' of annotated vectors. The annotations in blue are obtained from Larry's original BASIC macro. The annotations in green are created by the VBA project.
In order to try out the VBA macro …
Note: I've not written the code to annotate an arc. This version only annotates lines.
Please feel free to provide comments.
Hi Jon,
I know this is v8i forum. But , can this MVBA can also be run on V8 platform(08.05.00.64)?
I tried in v8 but it fails at " CommandState.CommandName = strAnnotateBearing " line
please suggest suitable changes.
regards.
Keyur
That statement was introduced with V8i. All you need to do is comment-out the line (or delete it).
thank you Jon
