Edit Data Field VS Fill in signle Enter Data Field
I managed to write a VBA script that scans a drawing and extracts number of text (either TextElements or TagSet or TextNode)
that are enclosed within a unique identifier, and then replaces them (with the text in thier new values )
into another new file (with the same drawing content).
The code scans these textsTobeReplaced, and stores the reference to the TextElement or TagSet. then prompts user for
new values (or via XLS sheet).
Now in the new file I am having this very wiered behaviour happening whereby, if I attempt to the fill in single enter-datafield
the new text entered is misbehaving. For instance.
Old Text: F11  (the length is 3 and center justified)
attempting to modify text using fill-in text editor with value of "F2", what happens is the justification is altered (to left)
and only "F" appears!!!
I spent some time comparing what has changed, I couldn't get to the buttom of it. I read the help page it indicates that
fill-in data should preserve original length and justification!
Note: If I try to modify the text using Text editor (for text nodes) it works fine!!! (I dont even have to alter the length or justification).
Is there something that I need to preserve and I'm not?
Thanks for the help in advance
  • Please post a code sample.
    Regards, Jon Summers
    LA Solutions
  • A snapshot of the code: btw this' not precisely what I'm using, but the core of it is.
    The guts of it is:
                            myText.Text = myWS.Cells(row, col)
                            myText.Rewrite ' I suspect this' a problem
       myEleFilter.ExcludeAllTypes
       myEleFilter.IncludeType msdElementTypeTag
       myEleFilter.IncludeType msdElementTypeText
       myEleFilter.IncludeType msdElementTypeTextNode
       myEleFilter.IncludeType msdElementTypeCellHeader
       Dim modelCount As Integer
       Dim myModel As String
       For modelCount = 1 To myDGN.Models.count
            If myDGN.Models(modelCount).Type = msdModelTypeSheet Then
                Set myEleEnum = myDGN.Models(myDGN.Models(modelCount).Name).Scan(myEleFilter)
                Set myWS = Excel.Sheets("TitleBox Data")
                Do While myEleEnum.MoveNext
                    If myEleEnum.Current.Type = msdElementTypeTag Then
                        Set myTag = myEleEnum.Current
                        If InStr(1, myTag.TagSetName, "Test", vbTextCompare) <> 0 Then
                            If InStr(1, myTag.TagDefinitionName, "APPROVED", vbTextCompare) Then
                                myTag.Value = myWS.Cells(3, 2)
                                If (StrComp(myWS.Cells(3, 3), "N", 1) = 0) Then
                                    myTag.IsHidden = True
                                Else
                                    myTag.IsHidden = False
                                End If
                            End If
                            myTag.Rewrite
                        End If
                Loop
            ElseIf myDGN.Models(modelCount).Type = msdModelTypeNormal Then
                Set myWS = Excel.Sheets("Drawing Data")
                'Loop within the Enum
                    If myEleEnum.Current.Type = msdElementTypeText Then
                        Set myText = myEleEnum.Current
                        If (StrComp(myText.Text, "bitOP2", 1) = 0) Then
                            myText.Text = myWS.Cells(5, 2)
                            myText.Rewrite
                        End If
                    End If
                    If myEleEnum.Current.Type = msdElementTypeTextNode Then
                        Set myTextNode = myEleEnum.Current
                        Set myEleEnum2 = myTextNode.GetSubElements
                        Do While myEleEnum2.MoveNext
                            If myEleEnum2.Current.Type = msdElementTypeText Then
                               Set myText= txtNodeElmntEnum.Current
                              If InStr(1, textElmnt.Text, DELIM, vbTextCompare) <> 0 Then
                                  myText.Text = myWS.Cells(6 2)
                                 myText.Rewrite
                             End If
                            End If
                        Loop
                    End If
                    If myEleEnum.Current.Type = msdElementTypeCellHeader Then
                        Set myCell = myEleEnum.Current
                        Set myEleEnum2 = myCell.GetSubElements
                            If myEleEnum2.Current.Type = msdElementTypeTextNode Then
                                Set myTextNode = myEleEnum2.Current
                                Set myEleEnum3 = myTextNode.GetSubElements
                                Do While myEleEnum3.MoveNext
                                    If myEleEnum3.Current.Type = msdElementTypeText Then
                                        Set myText = myEleEnum3.Current
                                        If (StrComp(myText.Text, " 1a ", 1) = 0) Then
                                            myText.Text = myWS.Cells(4, 3)
                                            myText.Rewrite
                                    End If
                                Loop
                            End If
                                Set myText = myEleEnum2.Current
                                If InStr(1, myText.Text, "OP1R", vbTextCompare) <> 0 Then
                                    myText.Text = myWS.Cells(4, 6)
                                    myText.Rewrite
                            End If
                        Loop
                    End If
               Loop
          End If
       Next
       myDGN.Save
       myDGN.Close 'Close Microstation
       myUstation.Quit 'Quit the program
    End Sub
  • Further to my earlier post, in a textNode, the field MAX_LENGTH has been set to the length of the new string rather than the original one!!
    for example if the text was $C1$ and the max length was set to 4, and the value user enters in the EXCEL sheet is 12, then the new length is 2!
    It seems that rewrite clears the length field, but keeps some other attributes as they are!
    I'm happy to mail the entire code with some drawings if required.
    Thanks for the help
  • I find such a large, monolithic, code block hard to follow, particularly so since some of the code is Excel VBA and other of the code is MicroStation VBA.
    Divide and conquer! Move code that deals with one topic into a procedure. It benefits us because your logic becomes easier to follow, and it benefits you for the same reason. It's not unusual to find, in six months time, that the code you write today looks like it was written by someone who uses the same style as you but whose logic is beyond comprehension.
    For example …
    Dim oModel As ModelReference
    For Each oModel In myDGN.Models
      Select Case oModel.Type
      Case msdModelTypeSheet
        Call SheetModelOperations (oModel)
      Case msdModelTypeNormal
        Call NormalModelOperations (oModel)
      End Select
    Next oModel
    Private Sub SheetModelOperations (ByVal oModel As ModelReference)
    End Sub
    Private Sub NormalModelOperations (ByVal oModel As ModelReference)
    End Sub
    LA Solutions
    LA Solutions
  • @Jon: Thanks for the advise, and I value the attempt to help. Cheers :)
    I figured out what the issue was. Basically the textElement I'm dealing with contained DataEntry and text.
    accessing both is not the same. And if you attempt to treat a DataEntry as text then the
    signle Enter Data Field would confuse the setting (I find this to be interesting and I still dont understand why)
    I have modified the code to treat each seperatly.
    What I call pure text is basically a textElement without a dataEntry.
    and I'm lucky that there's only two cases, one is a DataEntry ONLY and one as pure text.
    So here's how it looks now (which is an exact snapshot copy, unlike earlier code) :
    Note: drawRef.DrawingRef is equivilant to textElement or TagElement object
    class DrawingReference  ' Prototype copy
       Private o_drawingRef    As Object     ' This holds the reference to a TextElement or a TagElement
       Private s_referenceType As String
       Private s_originalText  As String
       Private s_finalText     As String
       Private s_TEXT_TYPE     As String
       Private s_TAG_TYPE      As String
    end class
    Public Function updateDrawingReference(ByRef errorStr As String) As Boolean
       Dim drawRef        As DrawingReference
       Dim s_finalText    As String
       Dim s_originalText As String
       Dim data           As DataEntryRegion
       For Each drawRef In c_drawingReferenceCollec
          s_finalText = ""
          s_originalText = drawRef.OriginalText
          If drawRef.isTextType Then
             If drawRef.DrawingRef.DataEntryRegionsCount = 1 Then
                s_originalText = drawRef.DrawingRef.DataEntryRegionText(1)
             End If
          End If
          If Not prepareSubText(s_originalText, s_finalText) Then
                errorStr = errorStr & "Unable to process " & drawRef.DrawingRef.Text & vbNewLine
                GoTo returnFalse
          End If
          drawRef.FinalText = s_finalText
          If drawRef.isTagType Then
             drawRef.DrawingRef.Value = drawRef.FinalText
          ElseIf drawRef.isTextType Then
             drawRef.DrawingRef.Text = ""
    'This' the key change here
    '            drawRef.DrawingRef.DataEntryRegionText(1) = ""
                ' update length of data field
                data = drawRef.DrawingRef.DataEntryRegion(1)
                data.Length = Len(drawRef.FinalText)
                drawRef.DrawingRef.DataEntryRegion(1) = data
                ' update the actual text of the field
                drawRef.DrawingRef.DataEntryRegionText(1) = drawRef.FinalText
             Else ' a pure text
                drawRef.DrawingRef.Text = drawRef.FinalText
             End If
          End If
          drawRef.DrawingRef.Redraw
          drawRef.DrawingRef.Rewrite
       Next drawRef
       If updateDrawingReference Then GoTo returnBack
    returnFalse:
       updateDrawingReference = False
    returnBack:
    End Function
Reply
    end class
          s_finalText = ""
             End If
          End If
                GoTo returnFalse
          End If
             Else ' a pure text
             End If
          End If
       Next drawRef
    returnFalse:
    returnBack:
    End Function
