Hi all,
I am new in the forum, I am not sure this post is in the correct section. If not, thank you in advance to let me know and redirect me.
I would like to develop a simple VB Routine to perform an automatic generation of electrical Microstation diagram from Excel.
The situation is;
In an Excel file, I have a table of at least 100 lines that represent 100 Electrical Consumers.
For each Consumer, there are specific text values like Cable Tag, Cable Size, type of Electrical Load...
The totality of the Consumers can be associated to 1 of 4 different Microstation Template drawings (Template already created).
I would like - for each consumers - to duplicate the associated template (listed in the Excel file Col. A) and replace all text values from that template by the corresponding text in the excel file.
I apologized for my bad English.
Thank you in advance.
Example for line 2:
Open "Template A.dgn"
Save it as "PM-01A.dgn"
Find text $MOTOR No$ and replace it by "PM-01A"
Find text $DESC$ and replace it by "Water Pump"
Close active dgn file (PM-01A.dgn)
perform the same task until the last row of the excel file.
because you want to develop it in VB and if you want to use MicroStation V8i or higher, you are in the right forum :-)
The "problem" is, that there is no question in your post - it is only information, what you want to do, so we can only assume your questions:
Can it be done? I am sure yes.
Can it be done in VB? I think yes, I personally prefer VBA, but both languages will be sufficient.
Is it easy task? Well, it depends how complex the drawings will be. If it will be only about to find text and to replace it with the appropriate cell value, it sound like simple task.
What is your knowledge of VB/VBA, MicroStation and MicroStation VBA development?
With regards,
Jan
Unknown said:I would like to replace all text values from that template by the corresponding text in the Excel file.
I recommend that you investigate MicroStation Tag Elements.
Locating and updating MicroStation text can be difficult, for various reasons. Tags provide structured data within a DGN model, similar to a table in a database. You can search for a named tag and update its value using VBA.
This article about Reading and Writing Tag Data may be useful.
Hello Jan,
Thank you for taking interest in my post.
Effectively, I forgot the most important...the question!!
so the question is, where do I start?
To answer your points:
- I know it is possible cos i have seen something similar made in BASIC (compile so can not read the code)
- I have microstation V8i.
- The routine is only about opening the correct 'template' and find text and replace it with appriopriate cell value.
- knowledge in Microstation development is nul.
- Pretty good level in Excel Macros development.
If I could get the code to start the declaration and variable and the listing of the object models for Microstation...
I should be able to manage the loop after that
Thank you for you tips and advised.
Realise as well I never signed!
Shame on me!
Heve
Thank you Jon,
I will investigate that way.
Hello again,
I had a lood at Tag Elements but not familiar and bit tricky.
feel more confortable with a find replace function...
Thanks in advance
Herve
Herve,
If you have experience with Excel VBA, then this MicroStation VBA code sample should get you started. Good luck.
Sub ReplaceText() Dim ee As ElementEnumerator Dim es As ElementScanCriteria Dim elArray() As Element Dim i As Long Dim iStart As Long Dim iEnd As Long ' ' set element scan criteria to find only text elements ' Set es = New ElementScanCriteria es.ExcludeAllTypes es.IncludeType msdElementTypeText ' ' set enumerator from active model ' Set ee = ActiveModelReference.Scan(es) ' ' get an element array of all elements found ' elArray = ee.BuildArrayFromContents iStart = LBound(elArray) iEnd = UBound(elArray) ' ' loop through array and replace text ' For i = iStart To iEnd If StrComp(elArray(i).AsTextElement.Text, "$MOTOR No$", vbTextCompare) = 0 Then elArray(i).AsTextElement.Text = "PM-01A" elArray(i).Rewrite End If Next End Sub
Rod WingSenior Systems Analyst
Hello Rod,I am busy these days and was not able to get in touch earlier.Thank you for the code above. I manage to make the loops and I have now to clean a bit the code as it contains lots of garbage.
To summarize, the Excel macro does: - Loop in Column B, - Open the template, - Save Template as value in Column A.
- Loop in Row 1, - Replace Text on Row 1 by text in Row xx
Now, everything is working very well with Microstation V8 (bit slow but working) but with Microstation J, I have a "Runtime error '70' - Permnission Denied" at the line code: elArray(i).AsTextElement.Text = cell3.Value.
If anyone have an idea?
Here below is the Code I have:
Sub Open_DGN()
Dim oCell As CellElementDim oScanCriteria As ElementScanCriteriaDim dFile As DesignFileDim curCell As ObjectDim MyDir As StringDim strPath As StringDim svPath As StringDim Path As StringDim LastRow As Long, LastCol As LongDim iRow As Long, iCol As LongDim cell1, cell2, cell3 As Range
''--- SET THE SCAN CRITERIA ---" Dim startPoint As Point3d Dim point As Point3d, point2 As Point3d Dim lngTemp As Long
LastRow = Range("B65536").End(xlUp).Row ' Last cell in Column B LastCol = Range("A1").End(xlToRight).Column ' Last cell in Row 1
''--- Loop until last Cell in Column B ---'' For iRow = 2 To LastRow Set cell1 = Cells(iRow, 2) cell1.Select
MyDir = ActiveWorkbook.Path ' Current path strPath = MyDir & "\" & cell1 ' Template name
Set dFile = OpenDesignFile(strPath, False) ' Open Template Name' Set oScanCriteria = New ElementScanCriteria svPath = MyDir & "\" & cell1.Offset(0, -1) dFile.SaveAs (svPath) ' Save Template Name as...
'' Start a command' CadInputQueue.SendCommand "MDL KEYIN FINDREPLACETEXT CHANGE DIALOGTEXT"
LastCol = Range("A1").End(xlToRight).Column ' Last cell in Row 1''--- Loop until last Cell in Column B ---'' For iCol = 2 To LastCol Set cell2 = Cells(1, iCol) Set cell3 = Cells(iRow, iCol) cell3.Select ''--- Loop through array and replace text ---''''--- Set element scan criteria to find only text elements ---''
Set es = New ElementScanCriteriaes.ExcludeAllTypeses.IncludeType msdElementTypeText
''--- Set enumerator from active model ---''Set ee = ActiveModelReference.Scan(es)''--- Get an element array of all elements found ---''elArray = ee.BuildArrayFromContentsiStart = LBound(elArray)iEnd = UBound(elArray)
For i = iStart To iEnd If StrComp(elArray(i).AsTextElement.Text, cell2.Value, vbTextCompare) = 0 Then elArray(i).AsTextElement.Text = cell3.Value elArray(i).Rewrite End IfNext
Next iCol Next iRow
End Sub
Unknown said:with Microstation J, I have a "Runtime error"
That's easy to understand: VBA was introduced with MicroStation V8 in 2001. MicroStation/J does not include VBA.
Thank you Jon, this is why in the Excel VB Help, there is the reference to V8 then.
However, why some part of the code above is working with Version J ?
i.e. If I remove the following part of code, the rest of the process works perfectly:
elArray(i).Rewrite
End If
Next
Thanks for your support.
Regards Herve
