V8i - VBA code for Printing from Excel
Hello all,
I am starting with VB for microstation and I would like to create a VBA macro in EXCEL that would allow me to print a selection of Microstation files to PDF files(based in a column).
For the looping process in Excel and opening the Microstation files from Excel, I do not have a problem but for the Print, aie aie!
Therefore, I used the Record facilities in VBA Project Manager and the result is below (Macro1). It is working fine but the only anoing thing is that it open 2 dialog Boxes:
      1 for the "select Printer Driver Configuration File" and 1 for the "Save Print As".
How could I avoid opening these 2 dialog Boxes and forcing the selection of a Printer Conf File and save as
Hello all,
I am starting with VB for microstation and I would like to create a VBA macro in EXCEL that would allow me to print a selection of Microstation files (based in a column).
Therefore, I used the Record facilities in VBA Project Manager and the result is below (Macro1). It is working fine but the only boring thing is that it open 2 dialog Boxes and this for all files!
Does anyone could help me on this? Thanks in adcance
Herve
Sub Macro1()
    Dim startPoint As Point3d
    Dim point As Point3d, point2 As Point3d
    Dim lngTemp As Long
'   Start a command
    CadInputQueue.SendCommand "FIT VIEW EXTENDED 1"
    CadInputQueue.SendCommand "DIALOG PLOT"
    CadInputQueue.SendCommand "MDL SILENTUNLOAD PENTABLE"
    CadInputQueue.SendCommand "PRINT DRIVER"
    Dim modalHandler As New Macro1ModalHandler
    AddModalDialogEventsHandler modalHandler
'   The following statement opens modal dialog "Select Printer Driver Configuration File"
'   Set a variable associated with a dialog box
    SetCExpressionValue "plotUI.uiPaperName", "ISO A3", "PLOTDLG"
    CadInputQueue.SendCommand "PRINT BOUNDARY FIT ALL"
'   The following statement opens modal dialog "Save Print As"
    CadInputQueue.SendCommand "PRINT EXECUTE"
    CadInputQueue.SendCommand "PRINT EXIT PLOTDLG"
    CadInputQueue.SendCommand "MDL UNLOAD PLOTDLG"
    RemoveModalDialogEventsHandler modalHandler
    CommandState.StartDefaultCommand
End Sub
Implements IModalDialogEvents
Private Sub IModalDialogEvents_OnDialogClosed(ByVal DialogBoxName As String, ByVal DialogResult As MsdDialogBoxResult)
End SubPrivate Sub IModalDialogEvents_OnDialogOpened(ByVal DialogBoxName As String, DialogResult As MsdDialogBoxResult)
    If DialogBoxName = "Select Printer Driver Configuration File" Then
        CadInputQueue.SendCommand "MDL COMMAND MGDSHOOK,fileList_setDirectoryCmd C:\Documents and Settings\All Users\Application Data\Bentley\MicroStation V8i (SELECTseries 1)\WorkSpace\System\pltcfg\"
        CadInputQueue.SendCommand "MDL COMMAND MGDSHOOK,fileList_setFileNameCmd Herve_Mono_pdf.pltcfg"
    '   Remove the following line to let the user close the dialog box.
        DialogResult = msdDialogBoxResultOK
    End If  ' Select Printer Driver Configuration File
    If DialogBoxName = "Save Print As" Then
        CadInputQueue.SendCommand "MDL COMMAND MGDSHOOK,fileList_setDirectoryCmd C:\Documents and Settings\All Users\Application Data\Bentley\MicroStation V8i (SELECTseries 1)\WorkSpace\Projects\Untitled\out\"
        CadInputQueue.SendCommand "MDL COMMAND MGDSHOOK,fileList_setFileNameCmd T1201.pdf"
    End If  ' Save Print As
End Sub
  • Printer Keyins
    You can do what you want using printer keyins. The trick is  …
    1. load the printer application without showing its dialog
    2. set print parameters using print keyins
    3. issue the print command to create your PDF
    The printer application is PLOTDLG …
    CadInputQueue.SendCommand "MDL LOAD PLOTDLG"
    The application commands all start with PRINT. You probably want to specify a printer configuration (.pltcfg) and possible a printer name …
    CadInputQueue.SendCommand "PRINT DRIVER " & "pdf.pltcfg"
    CadInputQueue.SendCommand "PRINT PRINTERNAME " & "Super-Duper Plotter"
    CadInputQueue.SendCommand "PRINT DIALOG"
    You can find further help on print commands from MicroStation help and using the keyin browser. If you keyin MDL LOAD PLOTCFG then keyin PRINT you will see a long list of options.
    Regards, Jon Summers
    LA Solutions
    LA Solutions
  • Thanks Jon for your quick solution,
    i will look at that asap.
  • Hello Jon,
    so I manage to select the printer configuration (.pltcfg) without opening the dialog box that is a good thing.
    The .pltcfg is a custom of a bentley driver (to create PDF) but i stil can not figure out how to select a directory to save the PDF and to na,e that PDF as the name of the actual design file...without opening the SAVE AS dialog box;
    in the macro, I have  CadInputQueue.SendCommand "PRINT EXECUTE " and this opens the dialog box; I would like to avoid that dialog box.
    Do you have any tip?? Thank you in advance.
    Sub PrintBW()
       Dim lngTemp As Long
    '   Start a command
       CadInputQueue.SendCommand "PRINT DRIVER C:\ProgramData\Bentley\MicroStation\WorkSpace\System\pltcfg\B&W_pdf.pltcfg"
       Dim modalHandler As New Macro2ModalHandler
    ''   The following statement opens modal dialog "Select Printer Driver Configuration File"
    ''   The following statement opens modal dialog "Save Print As"'
    '    RemoveModalDialogEventsHandler modalHandler
    End Sub
  • Unknown said:
    I can not figure out how to select a directory to save the PDF and to name that PDF as the name of the actual design file
    The MS_PLTFILES configuration variable tells Bentley drivers where to put the output file.  Search for Printing Configuration Variables in MicroStation help.
    The .pltcfg file provides a way to name the output.  Post a question to the Printing Forum if you can't find it in help.
    LA Solutions
  • Thank you Jon, I found partially the answer in the printing forum
    Herve
