"Append" a value to MS_DGNLIBLIST Config Variable path?
I wish to "append" (>) another library path to the MS_DGNLIBLIST variable within my MVBA.
1.
I can use the following but it replaces the value. How can I append a value please?
' Reset value of configuration variable path
ActiveWorkspace.AddConfigurationVariable "MS_DGNLIBLIST", "C:/Documents and Settings/All Users/Application Data/Bentley/Microstation/08.11.07.443/EE_WORKSPACE/WS_Standards/Standards/dgnlib/PrintStyles/ZS_PrintStyles_PORT_LEGACY_GREY.dgnlib"
2.
I also wish to use a variable for part of the path name than hardcode it?
' Append a value to the configuration variable path
ActiveWorkspace.AddConfigurationVariable "MS_DGNLIBLIST" > "$(_EE_STANDARDS)DGNLIB/PrintStyles/ZS_PrintStyles_PORT_LEGACY_GREY.dgnlib"
' Workspace Variables used
' _EE_STANDARDS = C:/Documents and Settings/All Users/Application Data/Bentley/Microstation/08.11.07.443/EE_WORKSPACE/WS_Standards/Standards/
Cheers, Colin
    What isn't working?
    _EE_STANDARDS = C:/ ... /Standards/ # OK
    MS_DGNLIBLIST > $(_EE_STANDARDS)DGNLIB/PrintStyles/ZS_PrintStyles_PORT_LEGACY_GREY.dgnlib
    Should append the DGNLIB to the list.  Make sure that file really exists!
    C:/Documents and Settings/All Users/Application Data/Bentley/Microstation/08.11.07.443/EE_WORKSPACE/WS_Standards/Standards/DGNLIB/PrintStyles/ZS_PrintStyles_PORT_LEGACY_GREY.dgnlib
    Regards, Jon Summers
    LA Solutions
  • Everything now works except for updating a configuration variable so that Print Organiser can see the new value. Even though I can confirm the MS_DGNLIBLIST has a new path to search, it doesn't seem to include the new Print Style DGNLIBs within that path, unless I close the DGN file and re-open it again?
  • The following link makes mention that changes to config variables only take effect once you restart MicroStation. That is precisely what I am seeing, but wish to overcome, for the new value I have assigned to MS_DGNLIBLIST?
    communities.bentley.com/.../49172.aspx
  • Ok; the key-in "mdl load cfgvars printCfgVarResource" creates "cfgvars.txt" and according to this list the variable does not require a restart of MicroStation. However, it does seem to require re-loading of the active project. How might I do this in VBA, without requiring the User to close and reopen the project?
    | Cfg Var Name             | Type           | Short Description              | Restart   | Project    |
    | MS_DGNLIBLIST            | Filelist       | DGN Library List               | NO        | YES        |
    Or am I still missing something here?
  • Unknown said:
    Am I still missing something here?
    No: it's the way MicroStation works.  In general, you can't load a configuration 'mid-stream'.  As you've found, you have to exit MicroStation and re-start to be sure that all configuration files are processed correctly.
    LA Solutions
Reply Children
