Ellipses Rotated Incorrectly
When I use the record macro feature in the vba project manager, say...to record placing a block, when i play the same macro back the scale is wrong (unless the ACS plane lock is on) and the ellipses are rotated 90 degrees in the x axis and 53 degrees in the y axis so they appear like a diagonal lines in the top view. By the way I'm new to microstation so I may need some help on terminology as well as coding.
Here is the some  code I'm having a problem with the ellipses in
Sub MacroDuct()   On Error GoTo errhnd   Dim selPts() As Point3d   Dim pt3TextPt As Point3d   Dim pt3dUL As Point3d   Dim pt3dUR As Point3d   Dim pt3dBL As Point3d   Dim pt3dBR As Point3d   Dim myCenPtT As Point3d   Dim myCenPtB As Point3d   Dim myCen As Point3d   Dim rotMatrix As Matrix3d   Dim myLine As LineElement   Dim myCir As EllipseElement   selPts = PointsByLine   CadInputQueue.SendReset   CommandState.StartDefaultCommand    'check for horizontal orientation   If selPts(0).X <> selPts(1).X Then       'set horizontal pts       pt3dUL.X = selPts(0).X       pt3dUL.Y = selPts(0).Y + 1.125       pt3dUL.Z = selPts(0).Z       pt3dUR.X = selPts(1).X       pt3dUR.Y = selPts(1).Y + 1.125       pt3dUR.Z = selPts(1).Z       pt3dBL.X = selPts(0).X       pt3dBL.Y = selPts(0).Y - 1.125       pt3dBL.Z = selPts(0).Z       pt3dBR.X = selPts(1).X       pt3dBR.Y = selPts(1).Y - 1.125       pt3dBR.Z = selPts(1).Z       myCenPtT.X = selPts(0).X + 2       myCenPtT.Y = selPts(0).Y + 0.5       myCenPtT.Z = selPts(0).Z       myCenPtB.X = selPts(0).X + 2       myCenPtB.Y = selPts(0).Y - 0.5       myCenPtB.Z = selPts(0).Z   Else       'set vertical pts       pt3dUL.X = selPts(0).X - 1.125       pt3dUL.Y = selPts(0).Y       pt3dUL.Z = selPts(0).Z       pt3dUR.X = selPts(0).X + 1.125       pt3dUR.Y = selPts(0).Y       pt3dUR.Z = selPts(0).Z       pt3dBL.X = selPts(1).X - 1.125       pt3dBL.Y = selPts(1).Y       pt3dBL.Z = selPts(1).Z       pt3dBR.X = selPts(1).X + 1.125       pt3dBR.Y = selPts(1).Y       pt3dBR.Z = selPts(1).Z   End If   Set myLine = CreateLineElement2(Nothing, pt3dUL, pt3dUR)       ActiveModelReference.AddElement myLine   Set myLine = CreateLineElement2(Nothing, pt3dBL, pt3dBR)       ActiveModelReference.AddElement myLine   Set myLine = CreateLineElement2(Nothing, pt3dUL, pt3dBL)       ActiveModelReference.AddElement myLine   Set myLine = CreateLineElement2(Nothing, pt3dUR, pt3dBR)       ActiveModelReference.AddElement myLine   Set myCir = CreateEllipseElement2(Nothing, myCen, 0.068, 0.068, rotMatrix)      ActiveModelReference.AddElement myCir   Set myCir = CreateEllipseElement2(Nothing, myCenPtB, 0.068, 0.068, rotMatrix)      ActiveModelReference.AddElement myCir   Exit Suberrhnd:   CadInputQueue.SendReset   CommandState.StartDefaultCommand   Select Case Err.Number       Case -12345           'Start Point not selected           MsgBox "Start Point not selected.", vbCritical       Case -12346           'End Point not selected           MsgBox "End Point not selected.", vbCritical   End SelectEnd SubFunction PointsByLine() As Point3d()   Dim myCIQ As CadInputQueue   Dim myCIM As CadInputMessage   Dim pt3Start As Point3d   Dim pt3End As Point3d   Dim selPts(0 To 1) As Point3d   Set myCIQ = CadInputQueue   Set myCIM = myCIQ.GetInput(msdCadInputTypeDataPoint, _                               msdCadInputTypeReset)   Select Case myCIM.InputType       Case msdCadInputTypeReset           Err.Raise -12345           Exit Function       Case msdCadInputTypeDataPoint           pt3Start = myCIM.point   End Select   CadInputQueue.SendCommand "LOCK AXIS ON"   CadInputQueue.SendCommand "PLACE LINE"   CadInputQueue.SendDataPoint pt3Start   Set myCIM = myCIQ.GetInput(msdCadInputTypeDataPoint, _                               msdCadInputTypeReset)   Select Case myCIM.InputType       Case msdCadInputTypeReset           Err.Raise -12346           Exit Function       Case msdCadInputTypeDataPoint           pt3End = myCIM.point   End Select   selPts(0) = pt3Start   selPts(1) = pt3End   PointsByLine = selPtsEnd Function
  • Initialise Data Correctly
    You use a rotation matrix without initialising that variable.
    When you declare a variable and don't assign it a value, VBA attempts to set a default value. For Example, an Integer defaults to a value of zero. However, VBA knows nothing about User Defined Types (UDTs) and doesn't know how to initialise them, so it sets the contents to zero in the hope that that might work.
    Unfortunately a default value of zero is not always a reasonable value for all UDTs. A rotation matrix with all members zero is invalid. To avoid this, initialise your variable like this …
    rotMatrix = Matrix3dIdentity
    Regards, Jon Summers
    LA Solutions
    LA Solutions
  • Jon
    Thanks for the reply. I tried initializing the rotmatrix variable, but I'm still having the same problem with my ellipses. The problem doesn't occur with text elements I place using the rotmatrix variable....only ellipse elements. Any thoughts?
  • Jon
    It works! Thanks. I temporarily changed my rotmatrix variable and forgot to change it back.
