I'd like to start an open source project on codeplex and develop the "RefRename.mvba" into a robust solution. There are a number of wrinkles to iron out with this idea, first and foremost is the ownership of the code and if Bentley would allow it. But the real question is if the programmers in the MicroStation Community would be interested in such a project.
So, if you might be willing to contribute to the solution reply to this post and let’s see if this thing has legs.
Some info on RefRename.mvba said: Bentley SELECT-Support ticketno:[8000537120]: Solution The example: RefRename.mvba can be downloaded from the following URL: ftp://ftp.bentley.com/pub/knowledgebase/attachments/RefRename.mvba This VBA example will change the reference file attachment by using 2 arguments. The 1st argument is the existing reference's full path and file name, the 2nd argument is the new reference's full path and file name. Steps: 1. Download V BA example "RefRename.mvba" 2. Place application in location pointed by MS_VBASEARCHDIRECTORIES (default is ...\Bentley\Workspace\System\vba\) 3. Start MicroStation (or open command file to be used in Batch processor). 4. Key-in: vba load RefRename.mvba vba run [refRename]startapp Example: Change the reference name of a file called "testref-01.dgn" to a new name "testref-02.dgn". Both files are in the same folder c:\references\ Key-in: vba load RefRename.mvba vba run [refRename]startapp c:\references\testref-01.dgn c:\references\testref-02.dgn Notes: -If file contains unresolved (red) references, a runtime error will report. The unresolved references need to be resolved or detached. -If there is undisplayed references, this will also cause the runtime error, enable "Cache when display off " in reference preferences.
Solution
Steps:
4. Key-in:
Example:
Key-in:
Notes:
Mike,
I like your idea. Ironically I just found this post as well as the original post and have spent a few hours understanding the original VBA. Being self taught, that might have taken me longer than for others ;-)
With that being said, I find this VBA to be A) over bloated (unneccesary steps) and B) doesn't work for files within PW. I was able to accomplish the same exact process with these few lines of code below:
Sub ReplaceRefAttachment()
Dim oAttachment As Attachment Dim oAttachments As attachments Dim RefName As String Dim OldRefName As String Dim NewRefName As String Set oAttachments = ActiveModelReference.attachments OldRefName = "PW_WORKDIR:dmsXXXXX\Border-old.dgn" NewRefName = "PW_WORKDIR:dmsXXXXX\Border.dgn" For Each oAttachment In oAttachments RefName = oAttachment.AttachName If RefName = OldRefName Then Set Attachment = oAttachment.Reattach(NewRefName, Model) End If Next End Sub
Maybe the Reattach Method was introduced after the original VBA was written(2003)? Couple of notes:
Hopefully someone else would like to expand on what I just started there, but for now, this gets the job done for me.
I made some changes to the above code. Following is the updated code.
Sub ReplaceRefAttachment() Dim oAttachment As Attachment Dim oAttachments As Attachments Dim RefName As String Dim OldRefName As String Dim NewRefName As String Set oAttachments = ActiveModelReference.Attachments OldRefName = "D:\1000\ABC101\Ref\Border-old.dgn" NewRefName = "D:\1000\ABC101\Ref\Border.dgn" For Each oAttachment In oAttachments RefName = oAttachment.DesignFile.FullName If RefName = OldRefName Then Debug.Print "Reference File Found..." Set Attachment = oAttachment.Reattach(NewRefName, vbNullString) End If Next End SubRegards,Leonard Jones.
