Hi there,
Is there another way to browse for a folder in Microstation VBA apart from using shell.application?
By this method it is not possible to set a default path.
Elahe
BTW these are my codes:
Dim objShell As Object
Dim objFolder As Object
Dim DGNDirName As String
Set objShell = CreateObject("Shell.Application")
Set objFolder = objShell.BrowseForFolder(0, "Please select a folder", BIF_NEWDIALOGSTYLE)
If (Not objFolder Is Nothing) Then
On Error Resume Next
If IsError(objFolder.Items.Item.Path) Then DGNDirName = CStr(objFolder): GoTo GotIt
On Error GoTo 0
DGNDirName = objFolder.Items.Item.Path
Else
If txtDGNFolder.Text = "" Then
MsgBox "Please Select A Path": GoTo Xit
GoTo Xit
End If
GotIt:
txtDGNFolder.Text = DGNDirName
Xit:
Set objFolder = Nothing
Set objShell = Nothing
Unknown said:Is there a way to browse for a folder in Microstation VBA
For reasons known only to itself, Microsoft failed to include the most frequently-used dialogs with VBA — the Windows Common Dialogs. The Windows Common Dialogs include File Open, File Save As and Browse for Folder and a few others.
Nevertheless, we show you how to implement File Open and File Save As dialogs.
Another article discusses a FolderBrowser ActiveX component. FolderBrowser is freeware.
Thanks John,
As usual you are a life saver. Interesting that you have mentioned it because the first time I wanted to write some code with VBA I was surprised that there is no CommonDialog in my toolbox?
I also tried to utilise FileDialog object by adding Excel library as reference and I end up with runtime errors.
Anyway the ActiveX I got from your website works well.
Cheers,
