Hi all,
I put the post here because it involves V8i but the problem comes from 2004 Edition. I've a application. I have an application programmed in Visual Basic.
It has always worked well with 2004 Edition. But install V8i and failure in the GetContents method in 2004 Edition.
If this same application (*.vbp or *.exe) her run on another computer with 2004 Edition does not fail. I don't understand. Any suggestions? Is it a bug?
Thanks in advance
