Morning all,
I've got an excel sheet which I use for managing tag values in my DGN's title blocks. Now all works fine when the tags are valid but for some reason if I work in a file that contains existing invalid tag elements which for some reason are invalid, it causes my excel sheet to stop working. My excel sheet operates by checking for a specific tagset yet these invalid tags are not from my tagset and it would be too much work delete and add valid tags in each file.
I noticed from the object browser that the tag element class has an isvalid property. Is there any way to have my import process (ie scanning target DGN file for tags and populating my spreadsheet with values of specific tags) ignore invalid tags so it will continue to return the tags I am looking for?
Barry Lothian said:My Excel sheet operates by checking for a specific tagset yet these invalid tags are not from my tagset
Note that the IsValid property is a generic property of all graphic elements. TagElement inherits it from base class Element.
Jon Summers said:How are you searching for the tag set?
In a specific cell within the excel sheet, the name of the tagset is entered. I appreciate you don't have the full code to work from, the basis for my excel file came from this file within this topic on which you previously assisted with historical queries of mine. I have made quite a few modifications to the original file in both code and GUI of the worksheet but the basis for tag element scanning remains the same.
Jon Summers said:What do you mean by an 'invalid tag'?
Its a tag element that you can be no longer edited using the edit tag command, If you click on it the status bar states that it is still a tag element but if you double-click it the message centre states its an invalid tag element. I'm unsure how Tags' break' like this but I do see it quite frequently ever since using V8i.
This is the error message that displays if comment out the error handler popup that tells me the dgn file has invalid tags.
Jon Summers said:Can't you simply ignore the tag set containing the invalid tags?
I don't believe so as I don't see any way to know which tagset the invalid tag comes from. Its almost like the tag has lost its association/link to its parent tagset from which it came from.
Jon Summers said:Note that the IsValid property is a generic property of all graphic elements. TagElement inherits it from base class Element.
Thanks, good to know. I just had a quick look to see if there was anything in the tagelement class that possibly sounded like it could work with the validity of tag elements.
So because these invalid tag elements exist and I can't exclude them by tagset, I'm thinking something along the lines of this is the way to proceed:
I've tried adding If oTag.IsValid = True Then after the If oTag.IsHidden = False Then line within the ImportTitleBlock tags sub however it hasn't solved the problem.
Have you any thoughts how to better implement the above or another way that will get round the issue?
Cheers Jon
Barry Lothian said: What do you mean by an 'invalid tag'? Its a tag element that you can be no longer edited using the edit tag command. Have you any thoughts how to better implement the above or another way that will get round the issue? [/quote] My first inclination would be to determine what is causing those tags to become 'invalid', and what that actually means. It's not something I've come across. If you can product a small DGN model that shows 'invalid' tags maybe someone could help. If an 'invalid' tag is something that can be produced in the normal flow of MicroStation activity then you should file a Trouble Report with Bentley Systems.
[/quote]
Certainly, this example contains the precise problem.
I'm not sure what it is that causes the tag to break but what I do know is that I have seen the same thing at my previous employer so I would say it was limited to our CAD configuration. It would be great to find out what causes it to happen but I'm not confident I ever will. Regarding my last query, do you have any code suggestions that would allow my macro to skip invalid tags? Was my suggested approach too simple or was it implemented in the wrong place?
Cheers
The 'invalid' tags, which should be associated with 'SOUTH ABUTMENT PLAN' have lost the ID of the host element. They are orphans.
The valid tags that are associated with 'SECTION' have retained the ID of the host element, which is your cell 'RUK -- pSection Title'. You can see the value 'Assoc ID of element attached to' if you use the Element Analyze tool to examine the tags.
Tags don't usually become invalid in normal use.
I don't think I could break them even if I wanted to so how its happening is a mystery. All I can do for now is try to avoid such instances affecting my excel macro.
Barry Lothian said:I don't think I could break them even if I wanted
The AddTag method is pretty foolproof. Since those invalid tags have become orphans, you should be able to reattach tags to those cells that have lost their tags. Delete the orphaned tags.
The delete tag command has no effect on such instances. I've just tried on the test dgn provided and the tags remain with no change.
I certainly don't have the time to go and fix all invalid tags that I encounter because:
a) I may not know where the location of tagset is
b) you can't easily tell if a tag is valid or invalid (if a drawing contains 100 tag elements and only 1 is invalid, it would be like finding a needle in a haystack to locate the invalid tag through trial and error.
The issue that they exist isn't a major problem in that the invalid tag still provides visible information on the drawing, the problems are if it needs changed or more importantly that it causes my excel document to fail when importing valid title block tag values. The latter is a major disruption to my workflow and it is this that at this moment I'm more concerned with finding a coding solution to (even though it would be good to happen upon the cause of tags becoming orphans)
If anyone has any suggestions how to ignore or skip invalid tags in VBA I'd be happy to listen to any suggestions
Barry Lothian said:The delete tag command has no effect on such instances
As I wrote, those tags are orphans. The delete tag command is looking for valid tags attached to a host element (when you use that command, it deletes not one but all tags attached to a host). The tags are elements nonetheless, and delete element despatches them to the eternal bit-box.
Barry Lothian said:You can't easily tell if a tag is valid or invalid
An invalid tag is an orphan; it doesn't have a host. Its BaseElement property will return Nothing. A valid tag returns a reference to, in your case, a cell.
Barry Lothian said:It would be like finding a needle in a haystack to locate the invalid tag through trial and error
Then don't use trial and error. Use software.
Barry Lothian said:It causes my excel document to fail when importing valid title block tag values. The latter is a major disruption to my workflow
How are you searching for title block tags? If you're scanning for tags, then you'll find the invalid tags as well as the valid ones. Why not scan for cells, filtering on the cell name and property, common to all elements, HasAnyTags? That way you'll find only those cells that have tags, and not any tags that don't have a host.
The worksheet contains a cell that holds the name of the target tagset. The specific tags within the tagset that I want to return the current values are found by using a specific row in the worksheet containing column headers that the tag values for each drawing are populated below e.g. Project No., Drawing Name, Project Title, Scale, Revision etc...
If the scan finds a cell called Revision that is hosted in my target tagset, its value is displayed in the row and the macro moves to the next cell in the row until the specific range of cells is at the end and the macro close the drawing down and opens the next, repeating to process until all files in the target folder are processed.
The reason I have not scanned for cells is that the tags are not in a cell, they are just individual tag elements (and associated Point geometry) inserted from file into the correct location.
