Does anyone know a method of finding the active file's dimension 2D/3D so it can be displayed as a text string?
Having sucessfully used the Application.Caption object.property to modify the tile bar contents, the default string containing [2D - V8 DGN] note is (obviously) overwrittten, I just want to add the 2D/3D info to my current caption string.
Marc Thomas said:Does anyone know a method of finding the active file's dimension?
A DGN file is dimensionless. It's a bag of Models. Each model has a dimension, but a DGN file may contain a mix of 2D and 3D models.
Marc Thomas said:Does anyone know a method of finding the active model's dimension so it can be displayed as a text string?
This article shows how to set MicroStation's title using VBA.
Hi Marc,
not tested it, but I think you should check ActiveModelReference.Is3D property.
HTH Jan
Thanks Jan, I'll take a look at that one.
Thanks Jon, and yes of course the default title bar caption changes to reflect the current model dimension.
Marc
Jan,
that's the one, thank you.
