Hi there,
I'm a little new to MicroStation, but have had success accessing the VBA API through C# in the past.
What's different this time is, I'm trying to create and open a new design file, merge in various contents, and present it to the user. When I try the following code,
BCOM.DesignFile dgn = ustn.CreateDesignFile(seed_file_name, newDGNFileName, true);
...the file is created, and MicroStation is opened, but without any Views, Toolbars, Menus, MDL Applications or any other GUI or other features. I get the same result when I set the Open flag to false then use OpenDesignFile to open the file instead. When I open the same file from Windows Explorer, however, it opens complete with all GUI features.
I expect this is to give a programmer greater control over the features needed to accomplish automated tasks, but have been unsuccessful finding anything in the VBA or MicroStation Help, or online, to get me where I want to go. I suspect I just don't know the uStn terminology to search for.
If anyone can help get me over this hump, I will be very grateful.
Orion
A code fragment is worth 1,000 words. Most COM servers for desktop application have a Visible property. Have you tried setting Visible = true?
Thank you, thank you, thank you. That was what I needed. It's been a while.
