As the title says I am wondering how in code I can target a specific model reference (ignoring all other model references in a designfile).An existing Macro I am trying to modify uses this:
Set oDgnFile = OpenDesignFileForProgram(oFile.Path, False)For modelCount = 1 To oDgnFile.Models.Count If oDgnFile.Models(modelCount).Type = msdModelTypeSheet Then myModel = oDgnFile.Models(modelCount).Name ElseIf oDgnFile.Models(modelCount).Type = msdModelTypeNormal Then myModel = oDgnFile.Models(modelCount).Name End IfSet oEnumerator = oDgnFile.Models(myModel).Scan(oScanCriteria)
What I am wanting is for my oEnumerator to only scan on a modelreference called Sheet. I know of the .Name property and its probably very easy to do but I can think how to put it all together.
Any help is appreciated.
Hi Gerald
Thanks for the example. I think before I misunderstood your first post, I was thinking that your example line ProcessMyModel oModel
contained additional code that you had not yet revealed. However I now realise that you were recommend that I encapsulate my succeeding code within the new sub. So having clarified all of that, I have done just that and it now seems to be on only the sheet reporting as desired. No doubt further quirks await but thay will save for another day.
Thanks again guys
