Project Explorer VBA
Hi
Does anyone know how to start Project Explorer but point to a specific file, every time you start it.  I want to use PE with the Selected file option.  I have a common project structure which contains a folder called data and inside this there is a common file called linkset.dgn.
What I want is to be able to press File > PE and for the icon to cal up a keyin in to then load up the projects linkset file i.e. maybe use MS_DEF/data.
I know the keying to launch PE, but I cannot find where to append the file name.
I know I can use the DGNLIB option, but this limits the usage of PE to the end user.
Ian Lapper
