http://translate.google.it/?hl=it&tab=wT#
I enclose two dgn 1) dgn with macro run 2) no macro dgn also attach macros I want the macro to include cells that are at minimum distance (set to 10 m). as he now takes all the cells. the if statement distmincalc <distmin not work or something I'm wrong. Programmer does not have anything I can do I studied in "Learning MicroStation VBA" and copied examples. also add that I know are English thanks to those who give me a hand
blumax57
You have used an incorrect variable name "distmincal" in your IF statement
If (distmincal < distmin) Then
It is undefined and will return a value of zero (0) and will be < distmin every time
The variable name should be "distmincalc", so the line should be
If (distmincalc < distmin) Then
Seems to work OK when I change that line
Also
I notice you had a counter line
i = 1 + 1
I think it should be
i = i + 1
Hope this helps
Ian Turner
thanks a lot
use OPTION EXPLICIT to avoid undefined variables
Frank
A LITTLE LATE BUT I UNDERSTAND :)
Frank_Klein said:use OPTION EXPLICIT to avoid undefined variables
blumax57 said:A LITTLE LATE
There's no time limit implied by your question. A response of four or five days including a weekend is OK. Be grateful!
You can read more about Option Explicit here, and how to make it the default setting in the VBA Interactive Development Environment (IDE).
I was not referring to the answer "late" but I understand that "late" thanks
good morning I wanted to ask you something
I like "progress bars" seen at the link http://www.la-solutions.co.uk/content/MVBA/MVBA-ProgressBar.htm
Click the icon and draw a ProgressBar on yourUserForm
UserForm
does not work may be the operating system?
win 7
I attach the error
This is a Microsoft issue. When you follow the instructions to add Addtional Controls to your UserForm, what Microsoft Progress Bar controls do you see?
I uploaded 2 macro:
progressbar and my macro macro
- when I insert the control in my macro gives me error
- when I insert the control in userform LASolution ok
see attached images
thanks
I just tried it with Microsoft ProgressBar v5 with no problem (see screenshot). My computer's operating system is Windows 7 Pro 64-bit.
What version of Windows are you using?
