http://translate.google.it/?hl=it&tab=wT#
I enclose two dgn 1) dgn with macro run 2) no macro dgn also attach macros I want the macro to include cells that are at minimum distance (set to 10 m). as he now takes all the cells. the if statement distmincalc <distmin not work or something I'm wrong. Programmer does not have anything I can do I studied in "Learning MicroStation VBA" and copied examples. also add that I know are English thanks to those who give me a hand
windows 7 professional
SP 1
64 bit
ram 8 GB
intel Core i7-2600 cpu 3.4 Ghz
I tried v5 Progress Bar does not work
and the result is that opens Geopak.msi???? maybe this is helpful?
thanks
please try using the Progress Bar on my userform
and return so I see how it works for me
If Geopak.msi is opening there are some windows installer and/or registry issues. You have to repair them first. The worst case would be : setup your windows 7 again.
Frank
