Hi, everyone,
I know there are similar post about this, But I cant find a Finally solution.
This time I´m gona need your great knowledge about programmig.I´m triying to make a "Macro" I´ve never done one before. So I Used to reading post and them copy paste, and normally woks, but this time dont.
I think That What I only need is add refference into a file.
By copy pasting, I get this
Sub Attach()
Dim myDGN As DesignFile Dim myTag As TagElement Dim myExcel As Excel.Application Dim myWS As Excel.Worksheet Dim CurRow As LongDim FileRow As Long CurRow = 2 Set myExcel = GetObject(, "Excel.Application") Set myWS = myExcel.ActiveSheet CurRow = myExcel.ActiveCell.Row FileRow = CurRow While myWS.Cells(CurRow, 1) <> "" Set myDGN = Application.OpenDesignFile( _ myWS.Cells(CurRow, 1), False) Set oModel = ActiveDesignFile CadInputQueue.SendKeyin "MODEL ACTIVE Model" 'CadInputQueue.SendKeyin "@C:\Autodesk\Path1.txt" myDGN.SavemyDGN.Close CurRow = CurRow + 1 Wend End Sub
But only works if the reference files are storage in my computer C:
I dont know if this is because the long of the path or because a specific configuration on the server we have. Something like \\ES\.........
The second try, Is this
Sub Attach2 ()
Dim myDGN As DesignFile Dim myTag As TagElement Dim myExcel As Excel.Application Dim myWS As Excel.Worksheet Dim CurRow As Long Dim CurCol As Long Dim FileRow As Long Dim Path1 As String CurRow = 2 Set myExcel = GetObject(, "Excel.Application") Set myWS = myExcel.ActiveSheet CurRow = myExcel.ActiveCell.Row FileRow = CurRow While myWS.Cells(CurRow, 1) <> "" Set myDGN = Application.OpenDesignFile( _ myWS.Cells(CurRow, 1), False) Set oModel = ActiveDesignFile CadInputQueue.SendKeyin "MODEL ACTIVE Model"
Dim oReference As Attachment
Set oReference = ActiveModelReference.Attachments.Add(myWS.Cells(CurRow, 2), Model, , , , , True, True)
Wend
End Sub
But when i try to run it. A message appear. "COMPILE ERROR, ARGUMENT NOT OPTIONAL.
Any Idea about what happen?Or any other solution ?
Any comment wil be very helpfull.thanks.Lucas ;)
Hi Lucas,
Unknown said:A message appear. "COMPILE ERROR, ARGUMENT NOT OPTIONAL.
For what line this error is reported? It's important information.
Unknown said:Any Idea about what happen?
I guess the error is reported for
It's not allowed to sckip arguments you don't want to take care about. If in the method specification a particular argument is not defined as optional (using square brackets [ ] ), you have always to pass such argument into the method. Declaration of .Add method (from MicroStation VBA help file) is:
Set Attachment = object.Add (FileSpecification, ModelName, LogicalName, Description, MasterOrigin, ReferenceOrigin [, TrueScale [, DisplayImmediately]])
It means you have to pass LogicalName, Description, MasterOrigin and ReferenceOrigin, not to use commas only.
Unknown said:Or any other solution ?
It's hard to say because you have not provided any description what you want to do and what worklow should be used. To extract it from the code is risky and not good idea in general, because you wrote you are beginner and created the code as a copy/paste, so it's not clear how close the code is to your requirements.
I also recommend to read and follow MicroStation Programming Forum best practices (specify version and language in a post subject, use Syntax Highlighter when any code is posted...). It will make your question better readable, which will increase a chance of quick answers.
To be frank, the code is not very clear and I don't understand some parts, e.g. why
is used.
With regards,
Jan
Thanks very much Jan Slerg.
Yes the error is in that line.
I
wrote this
Because, y need to attach the reference in this model, (there are dwg files, and the default name is Model)
so to change from sheet space to model space put this line (CadInputQueue.SendKeyin "MODEL ACTIVE Model")
I know that is not the Best, and only work if the model is named "Model".
Now it works, thanks to you.
I change the line, and add pt1 and Opt1 ( I dont know if I had to set this 3dpoints to 0,0,0. But as a wrote the reference goes to the correct place )
Sub ref()
Dim CurRow As Long
Dim CurCol As Long
Dim FileRow As Long
Dim Path1 As String
Dim pt1 As Point3d
Dim Opt1 As Point3d
CurRow = 2
FileRow = CurRow
Set oReference = ActiveModelReference.Attachments.Add(myWS.Cells(CurRow, 2), Model, (myWS.Cells(CurRow, 3)), 1, pt1, Opt1, True, True)
myDGN.Save
myDGN.Close
CurRow = CurRow + 1
The exel I use have this simple structure.
Y put the logical name, because i dont know other way.
Now I can say that this is solved :)
here the mbvaAttachFromExel.mvba
Unknown said:Now I can say that this is solved :)
With all respect, regardless you treated as solved, I don't think the code is workable and I have to say it's not good in my opinion.
I strongly recommend to start any VBA Module code with Option Explicit that will ensure all variables have to be defined explicitely, which decrease a threat of wrongly used variables.
I also see not used variables, personaly I hate to have all variables defined at the macro beginning, and also there are some not required commands (like Save and Close).
I guess it can be simplified to this form (with a little help of VBA wrapper of MDL function ;-).
Option Explicit Declare Function mdlSystem_newDesignFileAndModel Lib "stdmdlbltin.dll" (ByVal fileName As String, ByVal modelName As Long) As Long Sub ref() ' Get access to Excel Dim myExcel As Excel.Application Set myExcel = GetObject(, "Excel.Application") ' Get access to Excel active sheet Dim myWS As Excel.Worksheet Set myWS = myExcel.ActiveSheet ' Get active cell row number Dim CurRow As Long CurRow = myExcel.ActiveCell.Row ' Iterate through row from the active row While myWS.Cells(CurRow, 1) <> "" ' Open design file and specified model in one step OpenDesignFile myWS.Cells(CurRow, 1) mdlSystem_newDesignFileAndModel myWS.Cells(CurRow, 1), StrPtr("Model") ' Build full reference name (path + file name) from Excel cells Dim fullRefName As String fullRefName = myWS.Cells(CurRow, 2) & "\" & myWS.Cells(CurRow, 3) ' Define reference origin Dim referenceOrign As Point3d referenceOrign = Point3dZero ' Attach the reference to active model ActiveModelReference.Attachments.Add fullRefName, vbNullString, vbNullString, vbNullString, referenceOrign, referenceOrign, True, True CurRow = CurRow + 1 Wend End Sub
In fact this code is still quite poor, because there are no tests that operations (e.g. file opening) were finished without error and also no check for possible already existing reference attachment of the same file.
