Dear All,
need solution when I import or convert the AutoCAD drawing in MicroStation the many Tags appear with last Attribute information. how I can avoid them. I need only current used attributes only.
Hi Khalil,
Unknown said:many Tags appear with last Attribute information
I am not qute sure if I understand correctly your situation. Is it possible to share an example DWG?
By default, AutoCAD DWG attributes are automatically converted to tag sets and tags and I think there is no configuration or option that can be used to control how they are converted. But only attributes existing in DWG should be converted.
With regards,
Jan
