Hi all,
I would like to adjust my dimension text location programmatically to center / left / right.
For more details please refer the below snap shot.
I would like to adjust the top dimension text as shown in bottom dimension text.
Can any one help me how to do this.
Thanks in advance,
Kumar.
Hi Ram,
dimension text behavior is defined by dimension style. I recommend to test a proper dimension style setting manually. To change the dimension from the first to the second one, I assume more configuration have to be changed (Fit Options in Geometry, Text Justification etc.).
After you will now the right values, you can:
With regards,
Jan
