I have 2 cross section profiles of a train (front and back of the vehicle) in BSpline curve format and would like to join them together and create a BSpline Surface element in my C# microstation addin. I have tried to do this using the BSpline Surface.FromCrossSections Method but this does not seem to work.
Does anyone know of an appropriate method to achieve this or a similar result?
Ideally, I want to be able to display the outline of the vehicle in cross sections produced by Power Railtrack.
Matt Edwards Senior Permanent Way Engineer, Rail Matt.Edwards@wsp.com WSP Australia Pty Limited Level 27, 680 George Street Sydney NSW 2000 Australia wsp.com
Hi Mathew,
at first you have to specify what MicroStation version do you use (its build number ideally).
In some cases it's also important whether you use MicroStation addin or you control MicroStation externally using COM Interop.
With regards,
Jan
Hi Jan,
Thanks for the swift response.
I am using V8i SS3 Version 08.11.09.459.
The application is a .dll microstation addin.
Matt
