Dear all,
i am trying to create simple mdl application using text editor. I am write the code and compile the code using "Microstation development shell" but i get the following error.
"Error:"
Microstation Development Language Compiler 08.05.02Files.mc: Can't openNo such file or directory
Sample Code:
#include <mdl.h> #include <dlogitem.h> int main() { mdlDialog_openInfoBox(“Hello World!!”); return 0; } Here i attached my process screen shot:1.Create MC File
2.Enter the Header file Path.
3.Compile my Code:
4.Error Message.
thanks.
Hi Karthik,
Unknown said: so i request to you give me the step by step process that is very helpful for me
Frankly, you probably don't know what are you talking about. In my opinion to write down step by step process how to create and build MDL application, especially if it's not clear what your current knowledge is, so it should be basic and general, is several hours (and maybe be even a couple of days) work ... especially for non native English speaker as I am.
Unknown said: have some mdl codes collect from Microstation v8 MDL function Reference.chm
Why did you collect the code? MicroStation SDK is delivered with set of standard examples that can be used to start the learning. Moreover you can be sure they are tested and it's possible to compile them using bmake.
Unknown said:but i don't know where i am type the code and how to compile the code
Did you try to read MicroStation Programmer Guide? There are plenty of very useful information there.
Basic question is what is you current knowledge. Do you know C and how C code is compiled and linked? If not, I see no reason why to start to learn MDL, because such knowledge is crucial and mandatory. If you are not able to compile and link code manually using e.g. gcc compiler, plenty of topics in MDL will be not clear for you. MDL is Bentley properietary implementation of C language, but the main concepts (compilation to object files, lining obj with libraries etc.) are the same.
With regards,
Jan
In addition to Jan's recommendations...
