Dear all,
I am a VBA Developer i Need to develop the MDL Programming i am search in google for how to develop the mdl code i get the some references but the references not clear for me now i get the you tube link for develop mdl using vs2005 in that video they using MDLprojectwizard2005 for developing MDL. How to i download the MDLprojectwizard2005 if any one share the link for download it.
Karthik M
Hi Karthik,
the wizard is a part of MicroStation V8i SDK installation. If I remember correctly, you use MicroStation V8 2004 Edition, so this wizard cannot be used anyway, because Visual C++ 6 is required for V8.5, not Visual Studio 2005.
I have to say the wizard importance is often overrated in my opinion. It will not help you to understand the development better, it just automates some boring / annoying tasks, which is dangerous a bit, because it makes some topics to be black boxes.
A question of MDL learning materials has been discussed many times in this forum (e.g. this discussion). There are not many available of them available:
The mentioned sources of information expect you know C and C++. This knowledge is mandatory and required prior you start with MDL.
If there is anything not clear, ask specifically for this issue. In my opinion it's good to take some SDK example (e.g. Basic) and try to understand why it works. The problem is that in older SDK version all examples use MDL compilers and not Visual Studio compiler. It's fine if you need understand API, dialogs, resources and code structure, but e.g. bmake file is different.
With regards,
Jan
