Dear all,
I am using Microstation v8 2004 Edition with VBA and i need to be change the level number using VBA any one help me how to change the level number.
Karthik M
Hi jan,
Thanks for your response.
jan:-
why do you need to work with level numbers? My client give more important only on the level number not levels that is the reason i am work with level number. Regards, Karthik M
Unknown said:My client give more important only on the level number not levels
If the customer wants it, no other way then to accept it. But it's pretty bad decision which I guess can bring more troubles in future. In V8i no numbers are displayed for newly created levels so if any application relies on it, it has to be resistent against levels without a number.
Jan
