I need to get the "status" of each file in Raster Manager using VBA.
I don't see this attribute in the Raster object and have not found it in the VBA help.
I would think it would be in the "ExtendedInformation" property but it's not. Here is a screenshot and the code is below.
Thanks! Regan
Dim oRaster As rasterDim Count As LongDim AttachedRasterFilename As String
Set oRaster = RasterManager.Rasters.Item(Count)AttachedRasterFilename = oRaster.RasterInformation.Name With oRaster.RasterInformation Debug.Print "FullName = " & .FullName Debug.Print "Name = " & .Name Debug.Print "Filesize = " & .FileSize Debug.Print "IsFileConnectionLost = " & .IsFileConnectionLost Debug.Print "IsFileInvalid = " & .IsFileInvalid Debug.Print "IsFileMissing = " & .IsFileMissingEnd With
