Dear all,
I am using Microstation v8 2004 Edition with VBA. I trying to create a random points within the shape i did create points in order wise(ex.add points every 1m interval within shape) but my client need random points with in the shape so any one give me the reference to do it.
Thanks & Regards,
Karthik M
please try this VBA code below as simple example to create random points within a shape.You will need to first select a shape before executing the code.If no parameter is used, 1000 points will be placed within the shape. You may also give the number of points as start parameter.
I hope this helps?
Artur
Option Explicit Sub pointRandomShape() Dim counter As Long Dim i As Long Dim st As String Dim ele As Element Dim eE As ElementEnumerator Dim points() As Point3d Dim rng As Range3d Dim pRand As Point3d Dim oLine As LineElement st = KeyinArguments If Val(st) > 0 Then counter = Val(st) Else counter = 1000 ' arbitrary value if no parameter delivered End If Set eE = ActiveModelReference.GetSelectedElements If eE.MoveNext Then Set ele = eE.Current If ele.IsShapeElement Then points = ele.AsShapeElement.GetVertices rng = ele.AsShapeElement.Range i = 1 Do While i <= counter pRand.X = (rng.High.X - rng.Low.X) * Rnd + rng.Low.X pRand.Y = (rng.High.Y - rng.Low.Y) * Rnd + rng.Low.Y pRand.Z = 0 If Point3dInPolygonXY(pRand, points, -1) > 0 Then Set oLine = CreateLineElement2(Nothing, pRand, pRand) ActiveModelReference.AddElement oLine i = i + 1 End If Loop End If End If End Sub
With 3000 points I got this result:
