Dear all,
I am using Microstation v8i(SS3) and vba. i have linestring and i place the text(height of the vertex) every vertex of the LineString its working fine but it's coming irregular like some text comes above the linestring and some text below the line but i need above the line.How to i get it any method is available for do it.
Thanks & Regards,
Karthik M
Hi Karthik,
I agree with Frank more details would be helpful, both VBA code and also DGN file or at least a screen capture what situations you want to solve.
Unknown said:but it's coming irregular like some text comes above the linestring and some text below the line
It's not quite clear from your text if it's because the text is always in the same position and the line segment is crossing the text or the text itself is positioned irregularly in relation to the line string vertices.
Unknown said:but i need above the line
Can you provide an example what do you mean by "above the line". I can imagine "above line segment", but you wrote texts are placed at vertices.
Unknown said:How to i get it any method is available for do it.
I guess you will have to implement own method. VBA (in fact all MicroStation APIs) are usually "low level" and provide access to DGN format and related functions, but not to users functions like Place text (which are itself implemented using the same API).
Depending on your conditions and requirements it can be quite easy (just to move text somewhere outside line string) or very complex (analyze best with with e.g. potential text rotation).
With regards,
Jan
hi jan&Frank,
Thanks for your response and sorry for insufficient information. Here i attached my sample dgn and paste my vba code please find it.
Private Sub CreateText(ele As Element) Dim txtele As Element Dim hgt As Double Dim verts() As Point3d Dim i As Integer Dim pnt As Point3d Dim txtstr As String verts = ele.AsLineElement.GetVertices On Error Resume Next For i = 0 To UBound(verts) pnt = verts(i) hgt = pnt.Z txtstr = CStr(Round(hgt, 2)) Set txtele = CreateTextElement1(Nothing, txtstr, pnt, Matrix3dIdentity) ActiveModelReference.AddElement txtele txtele.AsTextElement.TextStyle.Height = 0.2 txtele.AsTextElement.TextStyle.Width = 0.2 txtele.Rewrite Next i End SubThanks & Regards,Karthik M
Text.dgn
my recommendations are:
... and it should be enough.
But be aware this approach is too simple and does not solve situation when the angle is small (sharp), so text will not fit inside empty space. In such case the first enhancement can be to test angle orientation, so text will be placed abow or below the line depending on angle at vertex. More complex enhancement can be to test text bounding box and moving the text to empty space ... but it easily can lead to complex code.
Hi jan,
I am change my code for calculate angle then place the text its working but its come based on the line direction so some place text is coming different direction please see my dgn.
3683.Text.dgn
